Use the Notes Microdialog
                With the Notes tool active, click inside the note to
                    display the microdialog.
- Step
- Use the arrows to move the note one step forward or backward along the curve.
- Peak
- Use the top arrows to move the note to the start and end points on the curve.
- Valley
- Snap To
 to move the note to the maximum
                                    peak.
                                    peak. to move the note to the minimum
                                    point on the curve.
                                    point on the curve.
