Cut and Paste to Other Applications
You can copy and paste data from the Values dialog to Excel.
  1. To copy data from a single column, left-click in the column header and press Ctrl + C to copy the data and paste it into Excel.
  2. To copy data from a single row, left-click in the row and press Ctrl + C to copy the data and paste it into Excel.
  3. To copy data from multiple columns, press Shift + left mouse button, select each column, and press Ctrl + C to copy the data and paste it into Excel.
    Note: Order is important. If you click the left mouse button first, HyperGraph treats it as a single-click event.
