Display Point Data in Decibels
For Line Charts:
  1. Under Scaling Options > Select the Target drop-down menu, select a vector.
  2. From the Select the Scale drop-down menu, select dB10 or dB20.
    The vector values are displayed in dB10 or dB20.
For Polar Charts:
  1. Under Scaling Options > Select the Target drop-down menu, select a magnitude vector.
