Tire Height Analysis
This is a quasi-static simulation during which the suspension is exercised from jounce to rebound and the corresponding spring and axle loads are reported.
Required input
Suspension travel:
    - Various values of left and right wheel center positions.
Task Description
The suspension is exercised to the different wheel center positions and a tabular report of the spring and axle loads is generated.
Output
A tabular report summarizing the wheel center displacements and the corresponding spring and axle loads is generated.
