Sequence of Straights and Arcs
[FF_STEER_CONTROLLER]
TAG                     = 'FEEDFORWARD'
LOOK_AHEAD_TIME         = 0.5
PATH                 = 'SEQUENCE_OF_ST_CRV'
BLOCK                = 'PATH'
INTEGRATION_STEP_SIZE   = 0.010000
AGGRESSIVE              = 'TRUE'
[PATH]
{KEY        PAR0              PAR1}
'ST'        20.000000         0.000000
'ARC'       40.000000        -6.283184This creates a path that is sequence of a straight (20 m) and arc (Radius 40 m, Angle
        6.283184 rad. clockwise).Figure 1.
[PATH]
{KEY        PAR0              PAR1}
'ST'        17.033191         0.000000
'ARC'       20.000000         -0.148890
'ST'        17.240436         0.000000
'ARC'       20.000000         0.148890
| [PATH] Sequence of straights and Arcs | ||
| TABLE | Attr - string | REQUIRED |
| COLUMN1 KEY | Attr - string | REQUIRED ‘ST’ for Straight and ‘ARC’ for arc |
| COLUMN2 PAR0 | Attr - Real | REQUIRED
| COLUMN3 | Attr - Real | OPTIONAL
