Task Wizard Dialog
The Task Wizard dialog allows you to select the analysis tasks to be run.
The dialog displays options related to the current model in a series of panels. For
                example, if you have assembled a standalone powertrain model, the task wizard only
                displays powertrain analysis options.
        - Next
- Moves to the next panel.
- Back
- Returns to the previous panel for review or edit.
- Cancel
- Closes the Task Wizard.
Front End Tasks
Analysis Setup
Vehicle Parameters
Kinematic and Compliance Parameters
Additional Options and Conditions
Any number of analysis tasks can be loaded into a model using the Task Wizard. Analysis tasks are displayed in the Model Browser. The analysis task is added to the model file when the model is saved so that it is loaded each time you open the model file.
Add an Analysis
The analysis may present Forms, if existing, for inputs that configure the
                analysis. Upon Finish, the analysis is imported into the
                    model.
Note: Multiple analyses can be added to a model
                    invoking the Task Wizard each time.
