Throttle-off Cornering
A Throttle-off cornering event simulates the dynamics of a vehicle driving a constant radius turn at steady state and the reaction of the vehicle due to a sudden removal of the drive torque while cornering.
The event includes a short straight section to allow the vehicle to come to steady state, the constant radius circle, throttle removal, and the subsequent vehicle reaction. A left or right turn can be simulated. The appropriate vehicle and tire output requests are included. A plot template is available to plot the results.
The Throttle off cornering event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
| Parameter Name | Description |
| Units | Describes the Length, Velocity, and Acceleration units.
| Radius | The radius of the circle that the vehicle CG follows during the constant radius portion of the event. |
| Initial straight | Length of the initial straight road section. |
| Velocity | Initial velocity of the vehicle until the throttle is switched off. |
| Initial lateral acceleration | Estimated initial lateral acceleration, calculated using the initial speed and the turn radius. |
| Turn direction | Direction the vehicle turns during the event (as seen by the driver). |
| Throttle step duration | Step duration of throttle to completely remove the drive torque. |
| Throttle delay | Time duration the throttle controller takes before the application of torque. |
| Transient time | Time duration for which the vehicle decelerates after switching off the Throttle. |
Controller Settings
- Non-leaning events (Cars/Trucks)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS- Use additional control: Enables the additional feedback control for the traction
                  control. The gains for the controller can be edited by toggling this check
                    box.Kp Proportional gain for the feedback PID controller Ki Integral gain for the feedback PID controller Kd Derivative gain for the feedback PID controller
                    box.
- Leaning events (Two-wheelers)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS - Use additional control: Enables the additional feedback control for the traction
                    box.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
- Flat Road
- Uses a flat smooth road for the event with no required road file.When the Flat Road is selected, the Graphics Setting option is available with the following parameters:- View path centerline: Enables the visualization of the event path.- This check box is disabled for open loop events without a path.
- View grid graphics: Enables the visualization of the road grid graphics.- When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
 Grid length Defines the length of the road. Enter a positive value in the model units. Grid Width Defines the width of the road. Enter a positive value in the model units. Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units. Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
- Road File
- The road file option enables the selection of a road file to be used in the event. Using this option, all tires in the model consider the event specified road file instead of the file included in the tire entities.
- Tires
- Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Automated Output Report
| Report Name | Report Signals |
| Steering Input and Acceleration |
| Longitudinal Tire Forces |
| Vehicle CG Displacement vs. Time |
