Access the HyperView - MultiCore Profile
  • To access the HyperView - MultiCore profile on Windows, select Altair 2024.1 > HyperView from the Start menu.
    • From the Startup dialog, select HyperView and use the Profile drop-down menu to select the MultiCore profile.
    • Click Create Session.
  • To access the HyperView - MultiCore profile on Linux, run hvmc from the <install_dir>/altair/scripts directory.
This will set the proper environment to run the MultiCore infrastructure.
