The Spring tool recognizes CBUSH connections and absorbs them as springs.
From the Certification ribbon, click the Spring
tool.
Figure 1. When Structural elements are created, a structural property can be
selected.
Click to define how properties are assigned.
Each structural element must have a structural property assigned to it in
order to run method.
Single property
Assigns the same structuralproperty entity to all designpoints.
Duplicate and assign property to all
Creates a new instance of the selected structuralproperty and
assigns the copy to all designpoints.
Duplicate and assign property per designpoint
Creates a new instance of selected structuralproperty per
designpoint entity.
This option performs a deep copy, meaning the structural property's
references, such as materiel/property, are also copied. Each
structural property generated is fully independent.
This is useful for design exploration where you will update
structural properties separately.
Select CBUSH elements to absorb as springs.
Optional: Select a destination designPointSet to hold newly created designpoints.
If no set is selected, a new one is created with config Spring.
If you enter
this menu from the Certification Browsercontext menu using Auto DDP, the selector is
pre-populated with the selected designpointset.
