Beam (Contact)
This realization creates beam elements between the shells and/or solid elements, connecting them using a contact definition.
Contact
- Creation
- Specifies how many contacts will be created depending on the number of links.
- Single Contact
- Specifies if the property created will be automatic or the sets will be user specified.
- Card Image
- Specifies the card image to be used in the contact definition(s).
Property and Material
- Material Card Image
- Defines the card image of the material(s) created.
Legacy Realizations
The following realizations are replaced by Beam (Contact):
- mat100
- mat196
- HC beam spotweld
- HC glue
- HC glue structural adhesives
- HC welding line
- HC hemming
