CFAST (General)
This realization creates CFAST elements between the connecting links.
Realization Details
- Diameter Option
- Specifies the diameter definition. Can be a diameter mapping file or a real positive value.
- Diameter/Diameter Mapping File
- Defines the diameter of the realization.
Connectivity
- CFAST Option
- Specifies whether the CFAST element will connect each link pair through properties (PROP) or through elements (ELEM).
- CFAST Suboption
- Specifies whether the CFAST element will be defined using nodes on links (GA – GB) or a single node in the middle of the projection from one link to the other (GS).
Legacy Realizations
The following realizations are replaced by CFAST (General):
- cfast_elem (GA – GB)
- cfast_elem (GS)
- cfast_prop (GA – GB)
- cfast_prop (GS)
