Charts
Chart entities plot X and Y data in the form of raw values. They also plot tables created in HyperMesh with the Matrix Browser or results data loaded for post-processing.
Restriction: The Chart entity is supported in
OptiStruct, Abaqus,
ANSYS, and Nastran
profiles.
Create and Edit Charts
In the Model Browser, right-click and select .
A new chart is added to the entity list.
- Use the Entity Editor to specify the name of the chart.
Select a data source.
- Direct Input
- Click
and manually enter X and Y values for the line chart.
- HM Table
- Use the Table selector that appears below to select a Table entity already created in HyperMesh. This could be a table created using the Matrix Browser. In the fields that appear under X axis and Y axis, select the appropriate X column and Y columns from the table respectively.
- Results
- Use the entity selector that appears to select Elements or Nodes. X-axis data is already assumed as Entity ID. Choose an appropriate data type and component for results to be plotted on the Y axis of the chart.
To plot a Chart:
- Optional: To view the data plotted in the Chart preview, right click in the chart preview and select Values.
- Optional:
Change various attributes of the chart in the Entity Editor.
- Symbol Style
- Provides options for adding a symbol to the curve label. You can set the style, color, frequency, and size of the symbol.
- Shade Area
- Provides options for shading parts of the graph in relation to the curve.
- Line Color
- Change the color of the curve.
- Line Thickness
- Chang the thickness of the curve.
- Line Style
- Options for displaying various line types.
- X-axis label
- Overwrite the current X-axis label shown in Chart preview.
- Y-axis label
- Overwrite the current Y-axis label shown in Chart preview.
