Cross Sections
Cross section entities store cross section definitions used in a crash analysis.
A cross section is defined by a set of nodes and elements. These sets can be explicitly defined in the entity or computed by intersecting a given geometry (plane, circle) with a set of elements or components.
Supported Solver Cards
Solver cards supported for cross sections.
LS-DYNA Cards
Card | Description |
*DATABASE_CROSS_SECTION_PLANE(ID) | XsectionPlane |
*DATABASE_CROSS_SECTION_SET(ID) | Define a cross section for resultant forces written to an ASCII file SECFORC. |
PAM-CRASH 2G
SECFO / | |
SECFO / NTYP = PLANE |
Transmission force at cutting plane Graphics available. |
SECFO / NTYP = CONTACT |
Cumulated contact forces No graphics available. |
SECFO / NTYP = LINK |
Cumulated link forces No graphics available. |
SECFO / NTYP = SECTION |
Transmission force at section No graphics available. |
SECFO / NTYP = SUPPORT |
Support reaction force No graphics available. |
SECFO / NTYP = VOLFRAC |
Fraction of volume affected by a defined criterion No graphics available. |
SECFO / NTYP = CONT_MS |
Contact forces between Main and Secondary nodal groups No graphics available. |
SECFO / NTYP = DETECT |
Accumulated nodal mass in selected volume No graphics available. |
SECFO / NTYPE = TIED_MS |
Tied forces between main and secondary nodal groups (v2018) |
Radioss Cards
/SECT | A section is a set of nodes and a set of
elements. Note: Block Format
Keyword |
/SECT/CIRCLE | A section is a set of nodes and a set of elements.
Sets are built automatically, by intersecting the concerned groups of elements with
a disc. Note: Block Format
Keyword |
/SECT/PARAL | A section is a set of nodes and a set of elements.
a parallelogram. Note: Block Format
Keyword |
Create Cross Sections
Create cross sections using the Cross Section Assistant.
In the Model Browser, right-click and select from the context menu.
The Cross Section Assistant dialog opens.
In the Cross Section Name field, enter a name for the cross section.
Note: If Create Multiple is enabled, the cross section name defines the prefix of each cross section created.
- In the Cross Section Type field, select the type of cross section to create.
- In the Entity Selection field, use the entity selector to select the mesh that will be cut by the cross section.
Select the Create Multiple checkbox to create multiple
cross sections simultaneously.
Note: When this checkbox is enabled, a cross section path definition will replace the Base Node and Normal Definition parameters.
- If you are creating multiple cross sections, in the Cross Section Path field, use the entity selector to select a node path for the creation of each cross section.
If you are creating a single cross section:
- Click Create.
