Edit Criteria and Parameter Files
Set the appropriate parameters/options to obtain the desired mesh by editing the criteria and parameter files.
Use the Criteria Editor and Parameters Editor to create and modify mesh criteria files as well as geometry cleanup parameter files.
From the Mesh ribbon, click either the
Param or the Criteria
tool.
Figure 1. Param Tool
Figure 2. Criteria Tool
- In the Criteria Editor and Parameter Editor dialogs, edit criteria and parameter settings.
Save your changes.
- Click
(Save File) to saves the currently loaded file. If no file is loaded, a prompt will be given for a new name.
- Click
(Save File As) save the current settings to a new or different file name.
- Click
- Click Apply to save your changes and continue editing or click OK to save your changes and close the window.
