Features
Detect, review, and manage geometric holes, fillets, flanges, and logos.
Create Features
Use the Features tool to find and create geometric features in the displayed model.
From the Topology ribbon, click the
Features tool.
If there are no Features in your model yet, the Feature Recognition Parameters dialog opens. - Select the feature types you want to find and enter the minimum and maximum dimensions to include in the detection.
Click Find to begin the detection process.
Tip: Using larger tolerances will capture more features but will increase processing time.
- Optional:
Click the Create Features satellite icon to manually
create features.
Tip: Select the Auto Compute check box to automatically compute the parameters. - Optional:
Click the List Features satellite icon to open the
Features view in the browser.
Figure 3.
Once the detection process is completed, the Feature Manager table opens.Figure 4.
Use the Feature Manager to select, review, and edit the detected
features.
By now, the feature entities are already in the model and can be also accessed via the Model Browser or by selecting them directly in the modeling window.The Feature Manager uses the same search, filter, and sorting mechanisms as the Model Browser.
- Status
- Green – Auto detected
- Empty
- A Feature that does not have any entities.
- Edit Feature
- Right-click on a feature in the manager.
- Select Edit Feature.
The functions on the toolbar are:Rerun feature detection
- Return to the Feature Recognition Parameters dialog. Clicking Find in this dialog first clears all features in the model currently then re-detects them using the current parameters.
Update
- Sync data and attributes for all, or individually selected features with their currently associated geometry or mesh.
Delete all features
- Clears all features from the model. To remove individual features, select them anywhere and press Delete.
Fit view to selected features
- Turn on to automatically fit the view to the features selected in the table.
- You can interact with features in the modeling window by setting the entity selector filter to Features with the mouse or by pressing the E key.
- Selection conversion between features and surfaces, lines, or elements (depending on feature type) is supported by switching the filter type with an active selection.
- Advanced selection methods are available for selecting features By Config, and geometry or mesh By Features.
Feature Types
HyperMesh supports the detection and management of the following feature types:
- Geometry
- 2D holes
- 3D holes
- Flanges
- Fillets
- Logos
- Mesh (FE)
- 2D holes
- 3D holes
- Flanges
- Both (Geometry + Mesh Associativity)
- 2D holes
- 3D holes
2D and 3D Holes
The following shapes and measured dimensions are supported for 2D holes:
- Circular
Figure 6.
- Rounded
Figure 7.
- Square
Figure 8.
- Rectangular
Figure 9.
- General
Figure 10.
- Defeature - Selected holes are defeatured using the same commands used by .
- Fill - Selected holes are filled with a filler surface using the same commands used by .
Flanges
Fillets
Fillets can be curved rounds (exterior) or fillets (interior) connecting surface edges in place of a corner. Their measured dimensions are minimum and maximum radius, minimum and maximum width, and minimum and maximum angle.
- Defeature - Selected fillets are defeatured using the same commands used by .
Logos
Logos are collections of surfaces representing symbols or letters that are embossed, etched, or machined into other surfaces. Their measured dimensions are size and height.
- Defeature - Selected logos are defeatured using the same commands used by .
