Perform Box Refinement
Use the Refine: Box tool to refine elements enclosed inside a box.
Before you begin, make sure the initial mesh is a regular mapped quad mesh, and not a free quad mesh.
From the 2D ribbon, click the tool.
- Optional:
On the guide bar, click
to define refinement options.
Select the center node to start the uniform mesh refinement.
A refinement box is created.
Adjust the size and shape of the refinement box by clicking on a face and
dragging the slider or inputting a value in the microdialog.
The refinement box determines the constant refinement zone. Elements inside this box should be the same size.
Click Transition: Elements on the guide bar.
A transition box is created.
Adjust the size and shape of the transition box in a similar manner to the
refinement box.
The mesh will be transitioned to match the initial mesh.Note: The transition box should enclose the refinement box. The size of the transition box determines how aggressive the transition will be. It is recommended that you limit the transition to 1 element connection 3 elements (1:3).
- Click Review on the guide bar to preview the box.
Click the box, enter a refinement size in the microdialog, then click Refine.
The size should be smaller than the initial mesh.
