Predict Results
Use the predict tool to generate a model prediction.
- Drag-and-drop an FE model file into the modeling window.
In the Load File dialog, define the options for the model
and click OK.
Note: To maintain performance, the license for physicsAI is drawn when a model is loaded as active. To release the license, the model should be released. -
In the Import Options dialog, click
Import.
The model opens in the modeling window.
From the PhysicsAI ribbon, select the
Predict tool.
The prediction will load in the modeling window.
