API and Customization
Enhancements
  • Python API
    • The implicit conversion of HyperMesh data type arguments has been improved and now supports the following types: hwDoubleList, hwDoubleList2, hwTriple, hwIntList2, hwIntList, hwBoolList, hwMatrix44, EntityList, EntityList2, hwStringList. For these argument types, you can directly supply a native Python list as the argument value.
    • Tabular attributes are now supported and can be queried or modified.
    • HyperMesh functions return a Python error in case of failure with a proper error message. Previously, the error was only captured in the returned status object and the Python code would proceed further.
    • Performance has been improved when creating an entity collection from a list of IDs.
    • Additional 10 query commands and 40 modify commands have been added to Python API as model instance methods.
Resolved Issues
  • Python API
    • Segmentation error caused by passing a non-active model object to CollectionByInteractiveSelection is resolved.
    • CollectionByDisplayed and CollectionByInteractiveSelection now return correct collection when working with Load classes (LoadAcceleration, LoadConstraint, LoadFlux, and so on).
    • Iterating over a collection and printing the entity object lead to the application freezing.
    • Entity class constructors returned an error when supplying an existing entity name or a name identical to the default name used by HyperMesh.
    • Incorrect size of a collection of surfaces from a collection of components created straight after running certain HyperMesh functions.
