Morphing
Enhancements
Domain Based Morphing Updates
Morph Library performance has been vastly improved. Specifically, the AutoFunctions domain creation and the creation of overlapping domains are now significantly quicker.
The cleanup process for domains has been improved. The cleanup process will start when you enter a morphing tool to reduce unexpected performance drops.
Resolved Issues
  • The On elements constraint is now only available for shell elements; solid elements were causing crashes.
  • An issue where the Remorph Changes option was not working as expected has been resolved.
  • An issue where some 2D domains were not being created due to overlapping elements has been resolved. You may notice a performance drop when creating 2D domains due to the number of domains now created.
