Highlight the connector(s) you want to convert, then right-click and select Convert > Style (spot, bolt, seamline) from the context menu.
The converted connector(s) will be unrealized and placed in the
Undefined folder. Once you convert a connector, you will not be able to revert
it back to its original state. The only information that will be retained
includes: number of layers, tolerance, and link information.
Convert Settings
Settings used to define how connectors are converted.
Access Convert Settings by right-clicking on a connector and
selecting Convert > Convert Settings from the context menu.
Table 1.
Option
Maintain as Line
To keep line connectors as line connectors after the
conversion, select the Maintain as Line
checkbox. When this checkbox is off, line connectors will be
converted to single point connectors per each connector
point.
Note: Only applicable when spot or boltlines are being
converted to seamlines.
