Update the attributes associated with a link, such as reconnection rule, link
references, and link state.
Update link operations are frequently used for:
Part replacement
Modify link rules
Modify link states
If a part replacement needs to be performed, the browser provides quick tools to
update one or more connectors with the link referencing the new redesigned part. The
following sections present steps to edit and update the link rule and the link state
attributes as well as the part replacement.
You can update links in the following ways:
Directly edit column data in the Connector Browser.
In the Connector Browser, select the link(s) or
connector(s) to update.
Click a field to edit the current value or select a new value.
In the Link Entity Browser, updates can be performed on a single or multiple
selected links. When you update a link in the Link Entity Browser, link
references will be automatically updated in the Connector Entity Browser. In the
Connector Entity Browser, updates can be performed for an individual link on a
single or multiple selected connectors in the Connector Entity Browser.
For
example, quickly change the reconnection rule from the Rule column, or
change the link state from the Elems/Geom column. Update links for the
purpose of part replacement by entering a new link ID or link name in the
Link Entity Browser. Part replacement can also be performed on single or
multiple selected connectors in the Connector Entity Browser by entering a
new link ID or link name in the Link column.Figure 1.
