From Surface Intersection
Extract curves from the intersection of two surfaces.
On the Geometry ribbon, select the From Surface
Intersection tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the
currently displayed tool. - Click and hold the currently displayed tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select
To combine all targets and newly created curves, in the
guide bar select Options
, then turn on Combine
Curves.
The Surface 1 button is active. Click the first
surface.
Tip: To change the first surface, click Surface 1, and then click another surface.
The Surface 2 button is active. Click the second
surface.
Tip: To change the second surface, click Surface 2, and then click another surface.
Select Apply
A new curve is created from the intersection of the two surfaces. - Right-click and mouse through the check mark to exit, or double-right-click.
