Prep Data Column Operations
When preparing data in Monarch Data Prep Studio, you can perform various operations not only for a single column but also for multiple columns of either the same data type or different data types. The availability of these operations depends on the data types of the columns selected. This section lists and defines the operations that you can perform when working with columns in Monarch Data Prep Studio.
Copy
Operation |
Data Type |
Description |
text, date/time, numeric |
Copies column values only or column values with headers to the clipboard. |
Creates a new table based on the columns and rows highlighted in an existing table. |
Filter
Operation |
Data Type |
Description |
text, number, date/time |
Launches the Define Filter dialog to create a new filter to apply to the table. |
Discard All Filters |
Removes all filters applied to the table |
Sort
Operation |
Data Type |
Description |
Sorts the column values in descending order |
Launches the Sort dialog to define a new sort order |
Column
Operation |
Data Type |
Description |
New Formula Column |
Adds a new formula column to the table |
Adds a new constant-value column to the table |
New Lookup Column |
Adds a new lookup column to the table |
Adds a new row-number column to the table |
Adds a new runtime parameter column to the table |
Adds metadata columns to your table |
Changes the column name. |
Creates a copy of a column. |
Hides the selected column |
Removes the selected column from the table. |
Show Hidden Column |
(Displays only when a hidden column exists in a table) Shows a list of hidden columns. Selecting a column from this list displays it in the table once more. |
Alignment
Operation |
Data Type |
Description |
Left |
Aligns all values to the left of the column |
Center |
Aligns all values at the center of the column |
Right |
Aligns all values to the right of the column |
Case
Operation |
Data Type |
Description |
text |
Converts to uppercase the first letter of each word in a string. |
text |
Converts all uppercase letters in a string to lowercase letters. |
text |
Converts a string to all uppercase letters. |
Clean
Operation |
Data Type |
Description |
text |
Trims all leading and trailing spaces from a string. |
text |
Trims to a single space any sequence of two or more consecutive spaces within a string. It also removes any leading or trailing spaces from the string. |
text |
Removes a sequence of characters from the values of the column you apply this operation to. |
text |
Removes all characters that are not numbers (0-9) or letters of the alphabet (A-Z/a-z) from a column value. |
text |
Removes all numbers from a column value. |
text |
Removes all alpha characters from a column |
Convert
Operation |
Data Type |
Description |
text |
Converts a text string to a numeric field. |
text |
Converts text fields with the values “X B,” “X M,” and “X K,” where “X” is any number, into “X,000,000,000,” “X,000,000,” and “X,000,” respectively. |
text |
Converts a string to a date/time. The date format will be: MM/DD/YYYY |
date/time |
Converts a text string containing time information (in HH:MM:SS format) to number of seconds. |
date/time |
Converts a date/time value to text. |
date/time |
Converts a date/time value to number. |
number |
Converts a numeric field to text. |
number |
Extract
Operation |
Data Type |
Description |
text |
Extracts n number of characters from the beginning of a string. |
text |
Extracts n number of characters from the end of a string. |
text |
Extracts n number of characters starting from a position you specify. |
text |
Extracts n number of characters starting from a start and end position indicated by a sequence of characters. |
text |
Extracts a line from a text block based on the number of the line in the block. |
text |
Extracts a line from a text block based on a given search term. |
Replace
Operation |
Data Type |
Description |
text |
Replace empty cells with the value of the first non-empty cell above it. |
text |
Replace null values with one more characters. |
text |
Replace blank values with one more characters. |
text |
Substitute a fixed sequence of characters with a different one. |
text |
Substitute a number of characters with a different set of characters starting from a set position. |
Split
Operation |
Data Type |
Description |
text |
Starts from the left and splits a column into two more columns, depending on a separator you define. The separator may be a single character or a substring. |
text |
Starts from the right and splits a column into two more columns, depending on a separator you define. The separator may be a single character or a substring. |
text |
Splits the value of a single name column into it's component name parts:
text |
Splits the value of a single address column into its component address or postal parts. When you apply this transformation, Prep Data will ask you which of the following name components are available:
date/time |
Splits a date/time field into two or columns according to the date/time components you select. |
date/time |
Splits a date/time field into two or columns according to the ISO 8601 date/time components you select. |
date/time |
Splits a date field into its components fiscal parts. |
Statistics
Operation |
Data Type |
Description |
Displays statistics about a column. Statistics will show you:
Allows you to create a new table including statistics of a row or several rows. |
Compute
Operation |
Data Type |
Description |
numeric |
Rounds number to a specified number of places to the right (or left) of the decimal point. |
numeric |
Rounds a number up to the nearest integer. |
numeric |
Rounds a number down to the nearest integer. |
numeric |
Returns the absolute value of the value of a column. |
Remove Decimals (Int) |
numeric |
Returns the Integer portion of a number. |
numeric |
Launches the Calculator dialog, which you can use to create a calculated field via a graphical interface |
Others
Operation |
Data Type |
Description |
Collapse changes unrelated to this column |
Allows you to collapse all items in the Change History list that are unrelated to the selected column. |
Allows you to:
Format (date/time) |
date/time |
Formats date/time columns |
Format (numeric) |
numeric |
Formats numeric columns |
text |
Inserts a constant text string at a specific location in a text field. |
Allows you to merge two columns into one. |
Allows you to redact the values of a column. |
Allows you to add or modify macros and apply the same to columns. |
Allows you to remove a column from the table. |
Multi-column operations
When working on multiple columns, you can perform various operations depending on the data types of the selected columns.
- The Duplicate Columns and Alignment operations are available for multiple columns regardless of data type.
- The Extract and Split operations are available for multiple columns containing text and date/time data.
- The Compute operation is available for multiple columns containing numeric data.
Selecting any of the Extract, Split, and Compute operations launches a corresponding dialog box.
From the dialog box, you can further modify the operation and manage the selected columns by sorting or filtering them.
