Modify a Template After Plot
View and modify plot parameters after plotting a result file.
Click
on the plot view.
The plot TOC is displayed with the applied template.Figure 1. Plot TOC
- Modify the plotting parameters of the template.
Choose one of the following:
- Click Save, the template is updated with the updated parameters.
- Click Set Template as Default, to set the template as a default
template. Note: If a default template is set for a result file then RVS will display the plot result directly. If the set default template doesn't match the result file, the Plot TOC is displayed with a message to select another valid template.
- Click Save As, to create a new plot template.
Click Plot to view the changes in the plot result.
Tip: Click
to clear the Y-axis selections.
