Add Polyhedral Particles
You can define a Polyhedral particle using one of the basic polyhedral particle shapes or an imported CAD geometry.
Right-click Bulk Material, select Add
Particle and then and select Add
Polyhedral.
A new Polyhedral particle is defined in the Creator Tree.
The Polyhedral solver supports convex polygons either defined using the EDEM Polyhedral shape library or an imported CAD geometry.
Note: Switching from Multi-Sphere to Polyhedral
particle is only supported at Time Step 0s.
