Define Volume Probes
Use the Probes tool to define volume probes.
When volume probes are defined, HyperMesh CFD writes all volume variables to disk at the request output interval.
                Create volume probes.
- Optional:
                Define volume probe settings in the microdialog.
                Figure 3.
- Optional:
                Import and export volume probes.
                - From the legend in the top-left of the modeling window, right-click the active probe set and select Probes table from the context menu.
                        In the dialog, select  to import volume probes. to import volume probes.
                        In the dialog, select  to export volume probes. to export volume probes.
 For more information, see Import, Export, and Edit Output Controls.
- Optional:
                Create probes from a rake.
                For more information, see Create Volume Probes from Rake.
                Change the color of probes.
                Move probes in the modeling window.
                From the guide bar, complete one of the following:
                - Select  to confirm your selection and continue creating
                        sets of probe points. to confirm your selection and continue creating
- Select  to
                        confirm your selection and exit the tool. to
- Select
