- hf_getautotippingangles
Return the auto-tipping angle along Z axis for selected mesh.
- hf_getdrawbeadforce
Calculates and returns the draw bead forces.
- hm_addchildrenoflistsinmark
Add children entities of lists in a mark.
- hm_ae_findattachmentsfromFEs
Returns resolved link entity information.
- hm_ae_get_partson
Returns the part IDs for given attachments.
- hm_ae_getfe
Returns the elements from the realized attachment.
- hm_ae_state
Return the current state of an attachment.
- hm_allentitiesinfo
Get information about all entities of the given type in the current model. A single call returns a list where every HyperMesh entity of the specified type (currently only assemblies, components, multibodies, materials, and properties are supported) is represented with a single list item. Each list item is identical to the return value of the command, hm_entityinfo all for that entity.
- hm_answernext
Provides an answer to the next command for Tcl scripts.
- hm_appendmark
Appends entities on a mark based on user supplied options.
- hm_assemlist
Returns the hierarchical structure of assemblies, and optionally standalone components and multibodies, along with properties, materials, groups and beamsection collectors.
- hm_attributeentitytype
Returns the entity type number of an entity attribute on an entity for the current template.
- hm_attributeidentifier
Returns the identifier flag of an attribute on an entity for the current template.
- hm_attributeidfromname
Returns an attribute ID from the attribute name for the current template.
- hm_attributeindexentitytype
Returns the entity type number of an indexed entity attribute on an entity.
- hm_attributeindexentitytypename
Returns the entity type string of an indexed entity attribute on an entity.
- hm_attributeindexidentifier
Returns the identifier flag of an indexed attribute on an entity.
- hm_attributeindexsolver
Returns the solver number of an indexed attribute on an entity.
- hm_attributeindexstatus
Returns the status flag of an indexed attribute on an entity.
- hm_attributeindextype
Returns the attribute type number of an indexed attribute on an entity.
- hm_attributeindextypename
Returns the attribute type string of an indexed attribute on an entity.
- hm_attributelist
Returns a list of all attribute IDs or names assigned to a specific entity for the current template.
- hm_attributelistall
Returns a list of all attribute IDs, names, types or type names for the current template.
- hm_attributenamefromid
Returns an attribute name from the attribute ID for the current template.
- hm_attributereferencecount
Returns the number of times an entity is referenced as an entity attribute.
- hm_attributesolverarrayvalues
Returns the solver code and all values for a 1D array attribute on an entity.
- hm_attributetype
Returns the attribute type number of an attribute for the current template.
- hm_attributetypename
Returns the attribute type string of an attribute for the current template.
- hm_bag_getconfigfromgenericname
Returns the bag configuration for the specified generic name.
- hm_bag_getentitytypes
Returns the types of entities inside a bag.
- hm_bag_getgenericnamefromconfig
Returns the generic bag name for the specified configuration.
- hm_bag_getsupportedconfiglist
Returns a list of supported bag configurations.
- hm_baglist_byconfig
Get a list of bag names or IDs of the specified bag configuration.
- hm_batchexportenginefile
Exports Radioss Engine and Starter files.
- hm_blockbrowserupdate
Controls the update of the browsers.
- hm_cardassignedtoentity
Indicates if a card can be assigned to the entities on the mark for the current template.
- hm_ce_alldetailsget
Returns all custom details assigned to a connector.
- hm_ce_cfglistget
Returns info on FE configurations for a specified solver, connector style and FE config file.
- hm_ce_checklinkentities
Returns the names or IDs of entities added to the connector that currently do not exist in the database.
- hm_ce_checkprojection
Check if the connectors make projection. Returns the failed connector IDs.
- hm_ce_close_mcf
Ends the process of reading a main connector file, triggered by hm_ce_read_mcf.
- hm_ce_datalist
Returns, in a list, all connector data displayed in the table for a single connector on mark and as a list of lists for multiple connectors.
- hm_ce_detailget
Returns certain details about a connector.
- hm_ce_errorreport
Returns the specific reason for the failed realization of a connector.
- hm_ce_fe_config
Gets the weld config defined for the connector.
- hm_ce_fedata
Returns the weld config or the tolerance set to realize a connector.
- hm_ce_findduplicates
Returns a list of connectors that are considered to be duplicates of other connectors, within a given tolerance.
- hm_ce_generatenamefrominclude
Returns a name using a base name and connector include ID.
- hm_ce_generatenamefromsubsystem
Returns a name using a base name and connector subsystem ID.
- hm_ce_getallfe
Returns specific FE and post created entity type(s) and ID(s) from a realized connector.
- hm_ce_getconfigfromconnectorcontrol
Gets the FE config name from a connector control or connector control default.
- hm_ce_getconnectorcontrol
Returns connector control or connector control default information from a connector.
- hm_ce_getconnectorcontrollist
Returns a list of connector controls or connector control defaults.
- hm_ce_getcords
Returns the location of the connector.
- hm_ce_getdefaultconnectorcontrolfromconfig
Returns the connector control default name and ID for an FE config.
- hm_ce_getfe
Returns specific weld ID(s) from a realized connector.
- hm_ce_getfeprojfeatureelems
Returns the independent or dependent layer of feature elements.
- hm_ce_getfeprojtrip
Returns the connector projection data for a specific layer.
- hm_ce_getfeprojweldnodes
Returns the independent or dependent layer of nodes belonging to weld elements.
- hm_ce_getfilteredconfignames
Get filtered config list for given connector style and type.
- hm_ce_getglobalsharedentitysettings
Gets the global shared entity management settings.
- hm_ce_gethmholes
Get bolt holes information from components.
- hm_ce_getlinkentities
Returns specific type of entities IDs that are added to a connector.
- hm_ce_getlinkentityinfo
Returns specific entity information for a connector.
- hm_ce_getlinkinfo
Returns link info for a connector including entity type, IDs/names, locator rule and XYZs.
- hm_ce_getnumoffeprojinfo
Returns the number of projection data stored in the array (size of array).
- hm_ce_getprojcompid
Returns the component ID for the projection data layer of interest.
- hm_ce_getprojectiondata
Returns newly created component projection information for a given set of connectors, points, or nodes.
- hm_ce_getprojfe
Returns the weld data list (types and IDs) for the given projection array index and weld array index.
- hm_ce_getprojfesize
Returns the number of welds created in a layer. This includes weld and rigids.
- hm_ce_getprojnodeid
Returns the node ID for the projection data layer of interest.
- hm_ce_getrealizedtestpoints
Gets the realized test points from the connector.
- hm_ce_getresolvedlinkentities
- hm_ce_getsolverprojectionbymark
Returns the solver projection data.
- hm_ce_gettestpoints
Gets the test point(s) from the connector.
- hm_ce_getthickness
Gets the total number of layers to be connected.
- hm_ce_getunsyncdata
Returns data which are not synchronized from the connectorcontrol assigned to a connector.
- hm_ce_getvalidabsolutepath
Returns a valid absolute path from a relative path.
- hm_ce_globalget
Get global variables related to connector display.
- hm_ce_imprintelemsget
Returns imprinted elements for a connector.
- hm_ce_info
Returns the requested information from a specified connector entity.
- hm_ce_linkprojectionorderget
Returns ordered projection information from links of spot connectors.
- hm_ce_mesh_imprint_option_get
Returns a mesh imprint option value.
- hm_ce_mesh_imprint_option_set
Sets a mesh imprint option value.
- hm_ce_numlinkentities
Returns the number of link entities for the connector.
- hm_ce_organize
Organizes displayed connectors into components by their definition.
- hm_ce_projecthexaface
Controls the creation of hexa elements for the ACM realization.
- hm_ce_read_mcf
Begins the process of reading a main connector file.
- hm_ce_setfeorientaxis
Set the axis aligned with the welds for the coordinates systems created during realization process.
- hm_ce_state
Returns the current connector state (unrealized, realized or failed).
- hm_ce_tooclosetoedgecheck
Checks if connectors are too close to an edge.
- hm_ce_type
Returns the type of a connector entity.
- hm_ce_xmlstringget
Returns connector information in XML format.
- hm_checkmark
Determines if the specified entity exists on the specified mark
- hm_checkproximity
Checks proximity between elements/components.
- hm_collisioncheck
Performs a collision detection.
- hm_collisionend
Clear memory and end the collision detection module.
- hm_collisionentitycreate
Adds entities to consider for collision detection.
- hm_collisiongetcomponententitypair
Returns the entity details for an entity collision pair.
- hm_collisiongetcomponententitypaircount
Returns the number of entity pairs for a component collision pair.
- hm_collisiongetcomponentlinesegment
Returns the start and end coordinates of intersection line segments.
- hm_collisiongetcomponentlinesegmentcount
Returns the number of line segment for the component collision pair.
- hm_collisiongetcomponentpair
Returns the component IDs of a collision pair.
- hm_collisiongetcomponentpaircount
Returns the number of component collision pairs.
- hm_collisiongetconfig
Returns flags to be used for configuration of the collision detection.
- hm_collisioninit
Initializes the collision detection module.
- hm_collisionvisualizebymark
Enables the visualization of collision entities using one of various supported visualization modes.
- hm_collisionwriteresultsfile
Writes the current collision results to a file.
- hm_compareend
Clear memory and end the comparison module.
- hm_compareentities
Generates comparison results for entities positioned at any location.
- hm_compareentitiesposition
Generates comparison results for entities positioned at a specific location.
- hm_compareentitiesrecursive
Generates recursive comparison results for entities positioned at any location.
- hm_compareentitiesrotate
Generates comparison results for entities rotated about a vector.
- hm_compareentitiessameside
Generates comparison results for entities positioned at the same location. This must be preceded by a call to hm_compareinit.
- hm_compareentitiessymmetry
Generates comparison results for entities positioned symmetrically about a plane.
- hm_compareentitiestranslate
Generates comparison results for entities translated along a vector.
- hm_comparefinddistances
Calculates the distance between all source and target entities.
- hm_comparegetarea
Calculates the area values for all source and target entities.
- hm_comparegetcomparea
Returns the comparison area of a specific component.
- hm_comparegetdistance
Returns the distance value for a specific distance index.
- hm_comparegetdistancecount
Returns the number of distances found.
- hm_comparegetdistanceentityid
Returns the entity ID for a specific distance index.
- hm_comparegetdistanceentitytype
Returns the entity type for a specific distance index.
- hm_comparegetdistancetransformid
Returns the transformation index for a specific distance index.
- hm_comparegettransformationcount
Returns the number of transformations found.
- hm_comparegettransformationmatchcount
Returns the number of matches for a specific transformation.
- hm_comparegettransformationmatchentities
Returns the entity IDs associated with a specific transformation and match.
- hm_comparegettransformationmatchentitycount
Returns the number of entities associated with a specific transformation and match.
- hm_comparegettransformationmatchentitytype
Returns the type of entities associated with a specific transformation and match.
- hm_comparegettransformationmatchstate
Returns the state of a specific transformation and match.
- hm_comparegettransformationmatchtype
Returns the type of a specific transformation and match.
- hm_comparegettransformationmatrix
Returns the 4x4 transformation matrix for a specific transformation.
- hm_compareinit
Initializes the comparison module.
- hm_comparereadfile
Reads comparison data from a file into the comparison database.
- hm_comparereturnresults
- hm_comparesetanalysismode
Specifies the analysis mode for element-to-surface comparisons.
- hm_comparesetelemsurfmode
Specifies whether to consider element centroids for element-to-surface comparisons.
- hm_comparesetflags
If enabled, the comparison module will cache extra pairwise data while performing comparisons between source and target.
- hm_comparesetignoreholes
Specifies whether to ignore holes and/or slots for 3D shell comparisons.
- hm_comparesetrefacetmode
Regenerates facets on source and target surfaces for comparison purposes.
- hm_comparesetreview
Sets the graphical review type for comparison results.
- hm_comparesetreviewcolor
Sets the graphical review color for comparison results.
- hm_comparesetreviewcolordefault
Sets the graphical review color for comparison results back to the defaults.
- hm_comparesetreviewmode
Sets the graphical review mode for comparison results.
- hm_comparesetreviewtypes
Sets the graphical review types to show for comparison results.
- hm_comparesettransparentmode
Sets the graphical transparency mode for non-reviewed entities.
- hm_comparewritefile
Writes the current comparison data to a file.
- hm_comparewritepairedcomps
Writes a list of pairs of source and target components to an output file.
- hm_comparewriteresults
Writes the current comparison results to a file.
- hm_controlcardattributedefined
Returns 1 if an attribute exists, 0 otherwise.
- hm_convertFromOutFileToDatFile
Generates a DAT file from an OUT file.
- hm_convertmarktorange
Converts a mark to an ID range and returns the ID range list with comma separators.
- hm_count
Counts the entities in the database.
- hm_createmark
Places entities on a mark based on user-supplied options.
- hm_defaultstatus
Returns the default status of an attribute.
- hm_defined
Queries whether an attribute or metadata is defined on an entity.
- hm_detectmeshpatterns
Evaluates mesh patterns and connectivity on an input quad/mixed mesh, and output problem elements onto a mark.
- hm_detectselfsymmetry
Finds and returns a point on the plane of symmetry and the normal of the plane.
- hm_diffencodings
Calculates the distance between two lists of encoded strings representing shapes of geometries.
- hm_elemlist
Get a list of element IDs or types for the passed component.
- hm_encodeshape
Generate an encoded string representing the shape of a geometry.
- hm_entitiesassociatedbygroupsmark
Selects entities associated through groups.
- hm_entity_setvector
Set the vector ID for the weld element.
- hm_entitycanselectby
Returns true if the passed entity type can be selected using the specified advanced method.
- hm_entitygettype
Returns the user-assigned entity type. The user-assigned entity type is set in the template.
- hm_entityincollector
Returns the number of entities in a collector.
- hm_entityinfo
Returns various information on entities.
- hm_entityisdirty
Returns dirtiness status of an entity.
- hm_entitylist
Returns a list of names or IDs of all entities of the requested type.
- hm_entitymaxid
Returns the maximum internal ID in use for an entity type.
- hm_entitymaxsolverid
Returns the maximum solver ID in use for an entity type.
- hm_entityminid
Returns the minimum internal ID in use for an entity type.
- hm_entityminsolverid
Returns the minimum solver ID in use for an entity type.
- hm_entityrecorder
Records the IDs of the entities created while the recorder is enabled.
- hm_estimategeomthicknesslimits
Returns the minimum and maximum thickness limits for thin solid geometry.
- hm_evaluatepythonexpression
Evaluates a Python expression.
- hm_excludebeyond
Removes entities from the base mark which are beyond the given distance or number of element rows from the entities on the target mark.
- hm_export
Exports data name values for entity hierarchy.
- hm_exportdummytargetpointstocsv
Exports the marked design points with ‘TargetPoint’ configuration to a CSV file.
- hm_exportentitydefaults
Exports the entity default setting values to an XML file in the current working directory.
- hm_exportidmgr
Exports the ID manager rules to a CSV or XML file.
- hm_exportoptimizationcards
Exports a Radioss optimization file.
- hm_exportplyorientation
Writes the fiber orientation vector for each element in a ply to a text file.
- hm_fe_getconfigfile
Returns the FE config file set for user-defined weld creation.
- hm_fe_getdiameter
Returns the diameter value set for weld or property creation.
- hm_fe_getdvstfile
Returns the dvst file set for weld or property creation.
- hm_fe_getWvsTfile
Returns the width versus thickness (wvst) file for weld or property creation on connector.
- hm_fe_setconfigfile
Set the FE configuration file for user-defined welds.
- hm_fe_setdvstfile
Set the diameter versus thickness file for user-defined welds on connector.
- hm_fe_setWvsTfile
Sets the width versus thickness file for seam welds.
- hm_findadvancedselectiongroups
Finds advanced selection entities and separates them into selection method specific groups.
- hm_findcirclefromthreepoints
Find the center and the radius of a circle that lies on three 2D points.
- hm_findclosestpointonline
For a given point on a line, returns the closest other point on that same line.
- hm_findclosestpointonsurface
For a given point on a surface, returns the closest other point on that same surface.
- hm_findconnectedpatches
Returns patches of connected elements.
- hm_finddeviation
Finds the deviation between two CAD geometries and returns a list of component pairs along with the deviation data.
- hm_findnarrowsurfaces
Returns the list of narrow surfaces, including large surfaces with narrow tails or local narrow neck regions.
- hm_findpolygonselection
Finds a polygonal path that connects all given input elements. This path takes into consideration the local mesh flow when defining a polygon.
- hm_findprojected
Finds nodes which lie on or within shells or solid faces, or which can be projected on to those shells or solid faces along a vector or element normal.
- hm_findtangentpointoncircle
From a point, find the corresponding two tangent points on a circle.
- hm_findthinsolidproximity
Finds and returns the proximate solid pairs for a given set of selected solids.
- hm_flangedetectionend
Clear memory and ends the flange detection module.
- hm_flangedetectionfindflanges
Executes the flange detection tools.
- hm_flangedetectionfindmates
Executes the flange mating tools.
- hm_flangedetectiongetflangedetails
Returns details about a specific flange.
- hm_flangedetectiongetflangemates
Returns indices of flanges that directly mate with the specified flange.
- hm_flangedetectiongetflangemidline
Returns offset boundary points for a given flange.
- hm_flangedetectiongetmatingentities
Returns the entities for two mating flanges.
- hm_flangedetectiongetmatinggroupdetails
Returns the members of a mating group.
- hm_flangedetectiongetnumberofflanges
Returns the number of found flanges.
- hm_flangedetectiongetnumberofmatinggroups
Returns the number of found flange mating 'groups'.
- hm_flangedetectioninit
Initializes the flange detection module.
- hm_flangedetectionsetparams
Defines parameters for finding flanges in both geometry and FE.
- hm_formnodelistsfrommark
Forms ordered node lists from a mark of nodes.
- hm_geomfindsymmetry
Finds and returns the symmetry transformation matrix and matched / unmatched surfaces between two selections.
- hm_getabsoluterotationvector
Returns a list {x y z} which describes the given entity’s absolute rotation. If HyperMesh is unable to locate the associated systems, the list will contain three empty members.
- hm_getactiveplotcontrolid
Returns the active plot control ID for a particular result plot type.
- hm_getactiveplotcontrolmaxvalue
Returns the maximum value for the active plot control together with the entity ID.
- hm_getactiveplotcontrolminvalue
Returns the minimum value for the active plot control together with the entity ID.
- hm_getactiveplotcontrolvalues
Queries the result values on entities for the active plot control.
- hm_getactivesimstep
Returns the active subcase ID and simulation step ID.
- hm_getaddendumid
Returns the IDs of the addendum surfaces.
- hm_getadjfacesfromface
Returns the faces adjacent to the specified face.
- hm_getadjsurfacesfromsurface
Returns the surfaces adjacent to the specified surface.
- hm_getadvancedselectiontypes
Returns a list of valid advanced selection strings for the specified entity type and mode.
- hm_getallmodels
Returns the names of the primary and all the secondary models.
- hm_getallmodelsinsession
Returns the names of the models in a current session.
- hm_getalltiedentities
Identifies groups of connected components and free parts within selected components.
- hm_getangle
Returns the angle between three nodes/points.
- hm_getareaofsurface
Returns the area of a surface.
- hm_getattachedsolidelemfaces
Returns information about solid elements attached to shell element faces.
- hm_getaverageelemsize
Returns the average element size for shell elements.
- hm_getaxisymmetricvolumereduced
Calculates the reduced volume of axisymmetric solids.
- hm_getbatchparams
Query the values of global mesh parameters.
- hm_getbestcirclecenter
Returns the center and radius of the best fit circle from the input nodes, points or lines.
- hm_getbinderid
Returns the IDs of the binder surfaces.
- hm_getboundingbox
Returns the bounding box of the specified entities.
- hm_getboundingbox_predefined
Returns the bounding box for a predefined box trim cut.
- hm_getcardimageoptions
Returns information about certain options supported by a card image.
- hm_getcardmark
This command returns the IDs (from the CARDINPUTLIST) for the entity type specified.
- hm_getcentroid
Returns the geometric centroid for selected entities.
- hm_getcleanupglobalflags
Returns the global flags currently being used for switching of some default modes for geometry autocleanup, element cleanup and element QI smoothing.
- hm_getclosedshelllayerelems
Separates thin closed-shell meshes into top and bottom layers.
- hm_getclosestnode
Returns the ID of the closest node to the point (x,y,z). Zero is returned if there are no nodes in the database.
- hm_getclosestpointsbetweenlinesurface
Find the shortest distance between a line and a surface, and return line and surface points corresponding to this distance.
- hm_getclosestpointsbetweentwolines
Find the shortest distance between two lines and return line points corresponding to this distance.
- hm_getcog
Returns the mass center-of-gravity coordinates for the selected entities.
- hm_getcollectorname
Returns the name of a collector.
- hm_getcommandfile
Returns the full path and file name of the command file.
- hm_getconfigtypecountincol
Returns a list indicating the entity config, type and count values that are contained in a collector.
- hm_getconfigtypeincol
Returns a list indicating the entity config and type values that are contained in a collector.
- hm_getconnected2delems
Returns lists of 2D shell elements and nodes that form t-connections or share edges at component boundaries.
- hm_getconnected3delems
Detects and categorizes connections involving 3D elements and provides a list of entities involved in the connections.
- hm_getcoordinatesfromnearestsurface
Finds coordinates of a point that belongs to one of surfaces in input set and is a closest point to the location specified in command input.
- hm_getcoordinatesofpointsonline
Gets the coordinates of the points for which normalized parameters are specified, along with the ID of the line on which they are located, as arguments to the command.
- hm_getcriteria
Query the values of global mesh quality criteria.
- hm_getcrossreferencedentities
Finds entities that reference the specified entity.
- hm_getcrossreferencedentitiesmark
Finds entities that reference the entities on the specified mark.
- hm_getcurrentframe
Returns the current animation frame.
- hm_getcurrenttime
Returns the current transient animation time.
- hm_getcurrentmodel
Returns the name of the current model.
- hm_getdatatypeaveraginglist
Returns a list of available averaging modes for the specified data type.
- hm_getdatatypecomponents
Returns a list of available data components for a specific result subcase and data type.
- hm_getdatatypelayers
Returns a list of available layers for a specific result subcase and data type.
- hm_getdatatyperesolvedinlist
Returns a list of available systems the specified data type can be resolved in.
- hm_getdefaultcardimage
Returns the default card image for the specified entity type for the current template/profile.
- hm_getdeleteassociatedentitiesbycompmark
Returns the unique associated entities for the components on a mark.
- hm_getdiameterfromfile
Returns the diameter for the specified thickness from the DVST file.
- hm_getdiedisplayattribute
Returns the die display attribute.
- hm_getdiepartid
Returns the IDs of the die part surfaces.
- hm_getdiepartshape
Returns the shape ID of the die part.
- hm_getdistance
Returns the distance between two nodes/points relative to a local coordinate system.
- hm_getdistancefromnearestline
Gets the distance of the given point from the nearest line with IDs specified as arguments.
- hm_getdistancefromnearestsurface
Gets the distance of the given point from the nearest of the surfaces with IDs specified as arguments.
- hm_getdrawbarid
Returns the IDs of the draw bar surfaces.
- hm_getdrawbeadattribute
Returns the attributes of the drawbar or drawbead created by the die module.
- hm_getdrawbeadid
Returns the IDs of the draw bead surfaces.
- hm_getduplicateelements
Returns a list of lists containing duplicate elements.
- hm_getedgeloops
Returns surface and element entities of specific connection types.
- hm_getedgeloops2
Returns surface and element boundary entities of specific connection types, and assumes any non-selected entities do not exist.
- hm_getedgesfromvertex
Returns all surface edges connected to a specified vertex point.
- hm_getelemcheckbounds
Returns the lower and upper bound values of the specified element check from the selected elements.
- hm_getelemcheckelems
Returns the elements from within a selection that match the specified element check criteria.
- hm_getelemchecksummary3d
Returns the 3D solid element quality summary.
- hm_getelemcheckvalues
Returns the check value for elements from within a selection.
- hm_getelementcheckmethod
Returns the method (solver) currently being used for calculating specific element quality checks.
- hm_getelementchecksettings
Returns the list of methods being used for calculating specific element quality checks.
- hm_getelementnormal
Returns the normal vector of the specified element vertex/edge/face.
- hm_getelementsqualityinfo
Computes quality parameters for the specified selection of elements.
- hm_getelementvolumes
Returns lists of shell element volumes and baffle elements in each volume.
- hm_getentities_dirty
Returns a list of dirty entities for an entity type.
- hm_getentitiesinboxes
Returns specified entities within boxes.
- hm_getentityalias
Returns the alias for a specified entity type.
- hm_getentitybasename
Returns the full HyperMesh entity type name for the passed entity type partial or short name.
- hm_getentitybundleinfo
Returns information about entity bundles.
- hm_getentitycardimagedictionary
Returns a list of card images for the specified entity type and card image organizational type defined in the current template.
- hm_getentitycreationid
Returns a valid entity ID that can be used to renumber both the creating and mapping entities.
- hm_getentityinfo
Returns definition information for an entity, either corresponding to the data name specified or all data names for that entity.
- hm_getentityname
Returns the full HyperMesh entity type name for the passed entity type ID.
- hm_getentityroot
Returns the ID of the root entity for a given modular entity type.
- hm_getentitytype
Returns the HyperMesh entity type ID for the passed entity type name.
- hm_getentitytypealiasname
Returns the alias name for a specified entity type in the current user profile.
- hm_getentitytypedictionary
Returns a list of card image types defined in the current template for the specified entity type.
- hm_getentitytypedisplayname
Returns the display name for the specified entity type.
- hm_getentitytypes
Returns a list of entity types based on the specified option.
- hm_getexistingentitytypes
Returns the list of entity types that exist in the current database.
- hm_getfacesbyarea
Gets the faces with an area smaller or equal to the specified value.
- hm_getfacesbyedgelength
Gets the faces that have an edge with a length smaller or equal to the specified value.
- hm_getfacesfromedge
Gets all faces connected to the edge whose ID is supplied as the argument.
- hm_getfacesfromsurface
Gets faces contained in the surface whose ID is supplied as the argument.
- hm_getfacesfromvertex
Gets all faces connected to the point whose ID is supplied as the argument.
- hm_getfilletfaces
Returns the faces containing fillets with a radius inside a range.
- hm_getfilletfacesbyprofile
Returns the faces containing fillets with a selected profile edge.
- hm_getfilletfacesfrommark
Returns the faces containing fillets with a radius inside a range, only considering specific faces.
- hm_getFLid
Returns the IDs of the flange lines.
- hm_getgeometricthinsolidinfo
Identify and return information on thin solid surface groups.
- hm_getgeometrynodes
Get a list of associated nodes from the set of geometric entities.
- hm_getgeomtopologytype
Returns the topology type of a geometric entity.
- hm_getgeomwithlargestitch
Returns the list of all surfaces, lines and points for which the topological stitch distance exceeds the input tolerance.
- hm_getguientityname
Returns the full HyperMesh entity type name with GUI style capitalization for the passed entity type ID.
- hm_gethistorylimit
Returns the maximum number of steps allowed to be recorded in the history.
- hm_gethistorymemorylimit
Returns the maximum amount of memory allowed to be used for recording history.
- hm_gethistorymemoryusage
Returns the current amount of memory used for recording history.
- hm_gethmfileuserprofile
Returns the user profile information saved in the HyperMesh database.
- hm_gethmfileversion
Returns the binary file version string for a specified HyperMesh database.
- hm_getidpoolnumber
Returns the ID pool number for a given solver and ID pool name.
- hm_getidpools
Returns a list of pool IDs or names for the specified entity type.
- hm_getidpoolsforidrange
Returns a list of pool names based on the specified entity type and solver ID range.
- hm_getincludeisolationentitiesmark
Returns the entities referenced/cross-referenced by the selected components, for include file organization purposes.
- hm_getincludes
Returns a list of include IDs or names.
- hm_getincludes_modified_since_last_export
Returns the include file IDs marked as dirty since the last export.
- hm_getincludesentities
Selects entities and returns the entity types contained in specified include files.
- hm_getincrementalname
Returns a unique incremental name from a specified base name and one or more entity types.
- hm_getinputoffsetid
Returns the current import offset ID value for the specified entity type.
- hm_getinternalid
Returns the internal HyperMesh ID for a solver ID and solver ID pool.
- hm_getinternalidlist
Returns the internal HyperMesh IDs for a list of solver IDs and a solver ID pool.
- hm_getinternalname
Returns the internal name for the specified pool string/pool ID and solver name.
- hm_getlinearclenpoint
Finds the coordinates of the point on the line that is at a given arc-length distance from another point on the line
- hm_getlineendpoint
Returns the components of the line end point.
- hm_getlinelineangle
Returns the angle between two lines at one of their intersection points.
- hm_getlinepointsatdistance
For a given line, test point, and distance, this command finds all of the line points that are at the specified distance from the test point.
- hm_getlinestartpoint
Returns the components of the line start point.
- hm_getlinetangentatcoordinate
Returns the closest point, the components of the tangent vector and the angle between the tangent vector and the z-axis at the point on the line closest to the input coordinates.
- hm_getlinetgendpoint
Returns the components of the tangent vector and the angle between the tangent vector and the z-axis at the line end point.
- hm_getlinetgstartpoint
Returns the components of the tangent vector and the angle between the tangent vector and the z-axis at the line start point.
- hm_getlinetype
Returns the line type.
- hm_getlist
Returns an ordered list of entities from an entity list.
- hm_getllsid
Returns the IDs of the latitude lines.
- hm_getlockedentities
Queries entity locks.
- hm_getmark
Returns the entity IDs of the passed entity type on the specified mark.
- hm_getmarkall
Returns a list of lists containing the populated entity type and entity IDs for the specified mark.
- hm_getmarkentitytypes
Returns a list of entity types that have entities populated on the specified mark.
- hm_getmarkfromtable
Returns the entity IDs from the specified table.
- hm_getmass
Returns the mass, volume and area of the selected elements or components.
- hm_getmatching
Performs a comparison and returns matching results.
- hm_getmatrixdifference
Given 4x4 transformation matrices M1 and M2, return the 4x4 matrix representing M1-1M2.
- hm_getmaxgapwidth
Returns the approximate maximum distance between a pair of node lists.
- hm_getmemoryinfo
Returns system memory information.
- hm_getmeshedgeparams
Returns all of the relevant automesh settings applied to that surface edge.
- hm_getmeshfaceparams
Returns all of the relevant automesh settings applied to that surface face.
- hm_getmeshvolumesinfo
Returns the number of volumes and lists containing the element IDs and volume indices for each input element.
- hm_getmethodinfo
Returns method information from the stress tool .
- hm_getmidsurfaceinfo
Returns information related to geometric midsurfaces.
- hm_getmidsurfcomp
Returns the name of the component in the model that contains middle surfaces and no other surfaces.
- hm_getmodelcheckconcernentityidresultentityid
Finds the list of untied nodes after a Model Checker run.
- hm_getmodelcheckcheckname
Returns the function name for a given check.
- hm_getmodelcheckcheckresult
Returns the result for a given check.
- hm_getmodelcheckcheckstatus
Returns the status for a given check.
- hm_getmodelcheckcorrectiondisplayname
Returns the correction names for a given check.
- hm_getmodelcheckcorrectionname
Returns the function for a given correction.
- hm_getmodelcheckcorrectvalue
Returns the value for a given correction.
- hm_getmodelcheckdefaultconfigfile
Returns the default model check config file for a profile.
- hm_getmodelcheckdisplaynames
Returns check display names.
- hm_getmodelcheckenttype
Returns the entity type for the specified Model Check check display name.
- hm_getmodelcheckfailedcount
Returns the number of entities failing a given model checker check.
- hm_getmodelcheckresultentids
Returns the entity IDs for the specified Model Check check display name.
- hm_getmodelchecksupportedentities
Returns the list of entity types that have checks.
- hm_getmodelchkvaluelevellimitcriteriaattribute
Returns model check values for level, limit, criteria and attributes.
- hm_getmoi
Returns the tensorial moment-of-inertia values for the selected entities.
- hm_getmoiofsolid
Calculate and return the 3 moment of inertia (Ixx, Iyy, Izz) and 3 product of inertia (Ixy/Iyx, Iyz/Izy, Ixz/Izx) values (MOI) for a single solid geometric entity.
- hm_getmultilevelreferenceentities
Finds all the multi-level reference entities for the entities specified on the input mark.
- hm_getmydocumentsdir
Returns the path to the current user’s "My Documents" folder on Windows.
- hm_getnearbyentities
Finds entities nearby entities on an input mark.
- hm_getnodalthickness
Gets the thickness of the node whose ID is given as the argument.
- hm_getnodegeometry
Get the simplest geometry entity associated with the node.
- hm_getnodeinitialcoords
Returns the node position on the initial associated geometry.
- hm_getnodessharedbyothercomps
Returns the nodes on the input components that are shared by other components.
- hm_getoccupiedentitiesinrange
Returns the list of occupied IDs in a specific range.
- hm_getoffset
Returns the offset value of the specified element.
- hm_getoffsetZ0
Returns the offset Z0 value of the specified element.
- hm_getoption
Returns the value of certain HyperMesh options.
- hm_getorientation
Returns a 4x4 matrix corresponding to the moment directions of the input.
- hm_getplanarfaces
Returns a list of planar face IDs.
- hm_getplaneintercepts
Returns the maximum and minimum points of a plane cross-section virtual intersection with entities.
- hm_getPOLid
Returns the IDs of the POL lines.
- hm_getpoolaliasname
Returns the alias name for a specified pool ID in current user profile.
- hm_getprefixbasenamesuffixforgivencompname
Returns the split name as prefix, base name and suffix for the specified component name and separator.
- hm_getprincipalaxes
Returns the principal axes direction cosines for the selected entities.
- hm_getprojceid
Returns the ID of the connector from the FE weld data array for a given index.
- hm_getqephtimestep
Returns the time step calculated from QEPH elements in a component.
- hm_getqualitycriteriaelementsizeinfo
Returns element size info for a quality criteria file.
- hm_getqualitycriteriastatus
Checks the status of the quality criteria.
- hm_getredoactions
Returns the history actions on the redo list.
- hm_getreferencedentities
Finds entities that are referenced by the specified entity.
- hm_getreferencedentitiesmark
Finds entities that are referenced by the entities on the specified mark.
- hm_getreplacecomponentpairing
Returns the component pairing for part replacement.
- hm_getreplacequerryonentities
Query information about a part replace preview operation.
- hm_getresults
Returns results data.
- hm_getribsid
Returns the IDs of the rib lines.
- hm_getshelloverlapinfo
Returns information regarding proximity overlap between a selection of components or elements.
- hm_getsketchdata
Queries the information about the entities present in the sketch.
- hm_getsolidboundsforsurfaces
Returns a list of bounding surface IDs, one list for each set of bounding surfaces found, or nothing if there is not a valid closed bounds found.
- hm_getsolidmappablestate
Returns the mappable state of the specified solid.
- hm_getsolidsfromsurface
Returns the list of solid IDs associated with a specified surface ID.
- hm_getsolidshelloverlapinfo
Returns information regarding proximity overlap between one/more solid cavity element(s) and structural components.
- hm_getsolver
Returns the name or ID of the solver as provided by the template *codename() command.
- hm_getsolvercards
Returns a list of solver cards (template tags) for either the specified entity type or solver ID pool.
- hm_getsolverfileprofilename
Returns the profile name for an FE input file.
- hm_getsolverid
Returns the solver ID and pool name for the specified HyperMesh internal ID.
- hm_getsolverid2
- hm_getsolverids
Returns the solver IDs and pool names for the specified HyperMesh internal IDs.
- hm_getsolverusessegmentsets
Queries whether the current solver profile supports segment sets.
- hm_getsourcecompsgroupsusingprefixbasenamesuffix
Returns a list of matching component IDs which have the same prefix-base-suffix name in the original model and an incoming model.
- hm_getsubcasedatatypes
Returns a list of available data types for a specific result subcase.
- hm_getsurfacecurvatureforedges
Returns information about the curvature of surfaces attached to edges.
- hm_getsurfaceedges
Get a list of edges associated with a specified ID.
- hm_getsurfacefromface
Gets the surface containing the face whose ID is supplied as the argument.
- hm_getsurfacenormal
Gets the normals of the surfaces connected to the node or point whose ID is given as the argument.
- hm_getsurfacenormalatcoordinate
Returns the closest point and the components of the normal vector at the point on the surface closest to the input coordinates.
- hm_getsurfacesbyarea
Gets the surfaces with an area smaller or equal to the specified value.
- hm_getsurfacesbyedgelength
Gets the surfaces that have an edge with a length smaller or equal to the specified value.
- hm_getsurfacesfromedge
Gets all surfaces connected to the edge whose ID is supplied as the argument.
- hm_getsurfacesfromsolid
Returns the list of surface IDs associated with a specified solid ID.
- hm_getsurfacesfromvertex
Gets all surfaces connected to the point whose ID is supplied as the argument.
- hm_getsurfacesurfaceangle
Finds the angle, measured in degrees, between two surfaces.
- hm_getsurfacethicknessvalues
Returns the midsurface thickness and offset values for nodes, points, or elements.
- hm_getsurfaceuvatcoordinate
Returns the nearest surface u,v coordinate from a given x, y, z location.
- hm_gettgofpointsonline
Returns the line coordinates and tangents at each of the given line u parameters.
- hm_getthickness
Returns the thickness of the specified component, element or property.
- hm_gettiedentities
Finds elements or components tied to nodes, elements, components or contactsurfs.
- hm_gettimestepaddedmass
Returns time step added mass for Radioss and Dyna.
- hm_getTLid
Returns the IDs of the trim lines.
- hm_gettotalcog
Returns the center of gravity of the entire model.
- hm_gettotalmass
Returns a list of model mass values.
- hm_gettotalmoi
Returns the total tensorial moment-of-inertia values of the model about the center of gravity.
- hm_gettracksid
Returns the ID of the tracks.
- hm_gettrimmedbinderid
Returns the IDs of the trimmed binder surfaces.
- hm_gettypefromidpoolnumber
Returns the type for a specified pool ID in the current user profile.
- hm_gettypesenabledfornamepools
Returns the entity types that are enabled for name pool.
- hm_gettypeswithunresolvedids
Returns a list of entity types that currently have unresolved IDs.
- hm_getundoactions
Returns the history actions on the undo list.
- hm_getunmeshedsurfstomark
Places the unmeshed surfaces from the input mark onto the output mark.
- hm_getunoffsetablenodes
Saves to the user list the unoffsetable nodes. Useful for CFD BL meshing.
- hm_getunresolvedidcrossreferences
Returns entities that are referring to an unresolved ID.
- hm_getunresolvedids
Returns the unresolved IDs for a specific entity type.
- hm_getunusedoremptyentities
Returns empty or unused entities.
- hm_getusermark
Returns the entity IDs of the passed entity type from the user mark.
- hm_getuvbounds
Returns the parametric uv coordinate bounds associated with the referenced surface.
- hm_getuvcoordinates
Returns the parametric uv coordinates at a node location on the referenced surface.
- hm_getuvvectors
Returns the parametric uv vectors at a node, point or xyz location on the referenced surface.
- hm_getvalue
Queries data names, attributes, and metadata on entities.
- hm_getverticesfromedge
Get surface edge endpoints.
- hm_getvolumeofsolid
Finds the volume of a solid entity specified by the solid entity’s ID.
- hm_getwhollycontainedcollectormark
Returns the collectors that fully contain the input entities.
- hm_getwrappoints
Returns a list of points, from the first input point to the third input point, that trace a convex path across the specified entities.
- hm_hierarchy
Returns the hierarchical structure of assemblies, components and multibodies, along with properties, materials, groups and beamsection collectors.
- hm_historyscriptunsupportedtofile
Writes out to files a summary of the unsupported commands contained inside .tcl script files.
- hm_historysupporttofile
Writes out to a file the commands that are supported for history.
- hm_holedetectionend
Clear memory and ends the hole/tube detection module.
- hm_holedetectionfindholes
Executes the hole/tube detection tools.
- hm_holedetectionfindmates
Executes the hole/tube mating tools.
- hm_holedetectiongetholedetails
Returns details about a specific hole/tube.
- hm_holedetectiongetholedetailsdata
Returns details about a specific query for a hole/tube.
- hm_holedetectiongetmatedetails
Returns details about a specific hole/tube mating 'group'.
- hm_holedetectiongetnumberofholes
Returns the number of found holes/tubes.
- hm_holedetectiongetnumberofmates
Returns the number of found hole/tube mating 'groups'.
- hm_holedetectiongetwasherelementslist
Returns the ID of washer elements layer-wise.
- hm_holedetectionidentifyhole
Returns the hole index for a given node or line.
- hm_holedetectioninit
Initializes the hole/tube detection module.
- hm_holedetectionsetentities
Defines the entities to consider for hole/tube detection.
- hm_holedetectionsetholeparams
Defines parameters for finding 2D holes in both geometry and FE.
- hm_holedetectionsettubeparams
Defines parameters for finding tubes in both geometry and FE.
- hm_idconvertmode
- hm_info
Query general information about HyperMesh options and paths.
- hm_intersectlineline
Find the intersection point of two lines.
- hm_iscurrentmodelprimary
Query if the current model is primary or secondary.
- hm_is_dirtiness_detection_enabled_for_entitytype
Informs if automatic dirtiness detection is enabled for the entity type.
- hm_isentitydatanameparameterized
Determines if a specific data name or attribute is parameterized.
- hm_isentitysupportedforaction
Determines if a particular entity type is supported for a certain action.
- hm_ishistorysupported
Returns the history support level for the specified command.
- hm_ispointinsidesolid
Checks whether a point is inside the volume of a solid geometry.
- hm_ispointinsidesolidelem
Checks whether a point is inside the volume of a solid element.
- hm_issurfacemappable
Checks whether the given surface can be mapped or not and returns the map shape and vertices of the shape.
- hm_istextcard
This command returns 1, for control cards if it is a string array card, else it returns 0.
- hm_jobs_addServer
Add a new server.
- hm_jobs_authenticateServer
Authenticates a server.
- hm_jobs_canSubmit
Reports if a job can be submitted on the current server without authentication.
- hm_jobs_editServer
Edits an already existing server.
- hm_jobs_getAppList
Returns the list of applications available for a given server.
- hm_jobs_getJobStatus
Returns the present status of a job on a server.
- hm_jobs_getServerDetails
Returns the name, IP and port of a server.
- hm_jobs_getServerList
Returns the list of servers added by HyperMesh.
- hm_jobs_getServerListFromServices
Returns the list of servers added by all applications.
- hm_jobs_getVersionList
Returns the list of versions available for a given application in a server.
- hm_jobs_removeServer
Removes a server.
- hm_jobs_setCurrentServer
Sets a server as current.
- hm_jobs_setServiceProperty
Sets a service property for the PBS-sensor.
- hm_jobs_startService
To explicitly start the PBS-sensor services.
- hm_jobs_submitBatchmeshJob
Submits a BatchMesh job to the server.
- hm_jobs_submitHSTJob
Submits a HyperStudy job to the server.
- hm_jobs_submitOptistructJob
Submits a OptiStruct job to the server.
- hm_jobs_terminateJob
Kills a running job.
- hm_latestentityid
Returns the ID of the last created entity.
- hm_linegetorderelems
Get the list of ordered 1D elements associated with input free lines for the given tolerance.
- hm_linegetordernodes
Get the list of ordered nodes associated with input free lines for the given tolerance.
- hm_linelength
Returns the sum of lengths of the lines whose IDs are given as arguments.
- hm_mapelementstoplane
Fast unfolding of a given set of connected shell elements onto a plane.
- hm_markbyfeature
Selects geometric entities by feature-based parameters.
- hm_markclear
Clear all entity IDs of the passed entity type from the specified mark.
- hm_markclearall
Clear all entity IDs for all entity types from the specified mark.
- hm_marklength
Returns the number of entities on the specified mark.
- hm_markremove
Removes entities from the specified mark.
- hm_marksearchmode
Defines the ID/name search order for *appendmark and *createmark.
- hm_marktotable
Creates a named mark table and populates it with the entities on a mark.
- hm_me_childrenget
Returns the first-level children module IDs.
- hm_me_entitiesall
Returns all of the entity types and IDs contained in a module.
- hm_me_entitiesget
Returns the entity IDs of a specific entity type contained in a module.
- hm_me_moduleget
Returns the module ID an entity belongs to.
- hm_me_modulesgetFromUid
Returns the list of module IDs for a given UID.
- hm_me_occrepkeyget
Returns the representation key of a part occurrence.
- hm_me_parentsget
Returns the recursive list of parent module IDs.
- hm_me_protoreplistget
Returns a list of the representation keys from a part prototype.
- hm_me_protoreptypeget
Returns the representation type of a part prototype.
- hm_me_repdetailget
Returns the requested metadata attributes from a part representation.
- hm_me_repfiledataget
Returns the representation file name and file format in a key-value form.
- hm_me_rootget
Returns the session-level root module ID.
- hm_measureshortestdistance
Measures the shortest distance between two entity selections.
- hm_measureshortestdistance2
Measures the shortest distance between a coordinate location and an entity selection.
- hm_metadata
Query the HyperMesh database for metadata.
- hm_modelcheckneedscorrection
Determines if an auto correction is required for a given check.
- hm_modelchecksavetoxml
Saves the config data to an XML file.
- hm_modent_getchildren
Get a mark of hierarchical children entities from a modular entity.
- hm_modent_getconstraintruleoptions
Returns a list of options that control the behavior of add/move/remove operations for a modular entity.
- hm_modent_getcontententitytypes
Returns a list of entity types contained in a modular entity.
- hm_modent_getcontentsbymark
Returns a mark of entities which are contents of a modular entity.
- hm_modent_getentityparent
Returns the hierarchical modular entity parent of a specific entity.
- hm_modent_getincludes
Returns the list of includes that are managed by a subsystem.
- hm_modent_getmodifiedbyids
Returns a list of modular entities modified after a representation has been realized.
- hm_modent_getrepresentationdefinitions
Returns the number of modular entity representations available, and those realized.
- hm_morph_getdomainangle
Returns the angle between two specified edge domains. Optional argument allows the user to input a normal vector to be used to measure the angle.
- hm_morph_getdomainarcangle
Returns the arc angle of a specified edge domain. Optional arguments allow the arc angle to be calculated using a line, node, or base point and axis to find the center of curvature.
- hm_morph_getdomainlength
Returns the length of a specified edge domain. Optional argument allows the user to input a vector along which to measure the length.
- hm_morph_getdomainradius
Returns the radius of a specified edge domain. Optional arguments allow the radius to be calculated using a line, node, or base point and axis to find the center of curvature.
- hm_morph_gethandledomains
Returns the domain IDs for the specified handle.
- hm_morph_gethandlenode
Returns the node ID for the specified handle.
- hm_morph_getinfo
Returns certain options/values from HyperMorph.
- hm_morph_getmvoledge
Returns the morph volume edge ID for the specified nodes along the edge.
- hm_morph_getmvoledgenodes
Returns the IDs of the nodes along a specified morph volume edge.
- hm_morph_getmvolface
Returns the morph volume face ID for the specified morph volume and nodes along the edges of that face.
- hm_morph_getnodehandle
Returns the handle ID for the specified node if a handle exists at that node.
- hm_morphupdatecheck
Identifies changes in the database relevant to HyperMorph entities and calls the necessary commands to update those HyperMorph entities.
- hm_nodeismidnode
Checks if a node is a mid-side node.
- hm_pathmanager
Returns all search paths, and runs a specified procedure for each path.
- hm_plotcontrol_update_begin
Initializes a sequence of updating multiple data names for a specified plotcontrol entity.
- hm_plotcontrol_update_end
Finalizes a sequence of updating multiple data names for a specified plotcontrol entity.
- hm_postcardeditorforentity
Posts a card editor for a selected entity.
- hm_postcardeditorformarkmask
Posts a card editor for a mark of entities.
- hm_projectpointonsegment
Returns the closest point to a specific point on a finite segment.
- hm_projectpointtosegment
Returns the closest point to a specific point on a segment.
- hm_projectpointtosegmentwithangle
Finds the projection point to a specific point on a segment along a specific direction.
- hm_proximityend
Clears the proximity calculation data and memory.
- hm_proximitygetcomponentelementpair
Returns a specific proximity element pair for a specific component pair.
- hm_proximitygetcomponentelementpaircount
Returns the number of element pairs for a specific component pair.
- hm_proximitygetcomponentpair
Returns a specific proximity component pair.
- hm_proximitygetcomponentpaircount
Returns the number of proximity component pairs.
- hm_proximitygetelementdistance
Returns the proximity distance for a given element.
- hm_proximityinit
Checks the proximity between elements or components, and stores the results internally.
- hm_proximityinitwithtarget
Checks the proximity between elements or components, allowing the user to specify the target, and stores the results internally.
- hm_proximitymarkcomponentallelementpairs
Marks the element pairs for a specific component pair.
- hm_proximitymarksourceproximityelements
Marks all the source elements within proximity to the given mark.
- hm_proximitymarktargetproximityelements
Marks all the target elements within proximity to the given mark.
- hm_removedieattribute
Removes the die attribute from an entity.
- hm_saveusermark
Store the entity IDs of the passed entity type on the user mark.
- hm_setdieattribute
Sets the die attribute for an entity.
- hm_setmodelcheckcheckstatus
Sets the run status for the specified Model Check check display name.
- hm_setmodelcheckcorrectionstatus
Sets the applied status for the specified Model Check correction display name.
- hm_setmodelcheckresultentids
Sets the entity IDs for the specified Model Check check display name.
- hm_setsolver
Sets theHyperMesh solver interface name in order to access entity information available for that solver.
- hm_solverconvert
Converts a model from one solver to another.
- hm_tableappend
Appends the contents of a HyperMesh table to another HyperMesh table of the same entity type. Creates a destination table if it does not exist.
- hm_tableclear
Clear a table (all memory is freed).
- hm_tableclearall
Clear all tables (all memory is freed).
- hm_tablecopy
Makes a copy of the HyperMesh table. Overwrites destination table.
- hm_tabledifference
Finds the difference of two HyperMesh tables of the same entity type (subtracts the contents of the second table from the first table) and places the result in the first table.
- hm_tableintersection
Finds subset of entities common to two HyperMesh tables of the same entity type and places it into the first table.
- hm_tablelist
List the names of all tables created by marktotable.
- hm_tablelookup
Search a table for an entity ID. The constant 1 is returned if the ID is found. Otherwise, 0 is returned.
- hm_tabletomark
Append the entity IDs from the named table to the specified mark.
- hm_triplecos
Get the cosine angle of two vectors.
- hm_undefinedmatchingcriteria
Returns the supported undefined matching criteria for a given entity type.
- hm_updatemodelcheckresultvalues
Updates the failed values for the model check entity.
- hm_visualizeloads
Plots engineering loads referenced by a load collector.
- hm_wadlinescheckentities
Checks front and rear entities for validity.
- hm_wadlinesend
Clear memory and end the WAD lines module.
- hm_wadlinesgetadulttestzone
Returns the coordinates of the adult test zone boundary.
- hm_wadlinesgetchildtestzone
Returns the coordinates of the child test zone boundary.
- hm_wadlinesgetdebugtracelines
Creates the debug lines used to create different types of reference lines, and returns the coordinates.
- hm_wadlinesgetgridpoints
Returns coordinate data defining WAD grid points.
- hm_wadlinesgetgridpointsleg
Returns grid points for either upper or lower leg impact analysis.
- hm_wadlinesgetinternalbumperline
Returns the averaged points for the internal bumper line as a series of x, y, and z values.
- hm_wadlinesgetleggridline
Returns a series of three doubles denoting the points for the line calculated by the previous call to hm_wadlinesgetgridpointsleg.
- hm_wadlinesgetreferenceline
Returns coordinate data defining WAD reference lines.
- hm_wadlinesgetsectionmax
Returns the most outward intercept of a cross section of the model as measured in a given direction.
- hm_wadlinesgetwadline
Returns coordinate data defining a WAD line.
- hm_wadlinesgetwadpointtapeline
Returns coordinate data defining a line made by the measuring tape running from the ground to the specified WAD point along the vehicle.
- hm_wadlinesinit
Initializes the WAD lines module.
- hm_wadlinesispointintestzone
Returns whether a point is inside a test zone by taking in the coordinates of the zone boundary.
- hm_wadlinessetbumper
Sets the entities for the internal bumper components used for the internal bumper reference line and upper/lower leg grid point generation.
- hm_wadlinessetfrontentitiesforcollision
Sets the front entities to be used to create the bonnet rear reference line.
- hm_wadlinessetentities
Sets the entities used for a WAD lines analysis.
- hm_wadlinessethood
Sets the entities for the hood used to create the reference line.
- hm_wadlinessetoptions
Sets various WAD lines module options.
- hm_wadlinessetparameters
Sets basic parameters for a WAD lines analysis.
- hm_wadlinessetaxes
Sets the origin and coordinate axes for a WAD lines analysis.
- hm_wadlinessetwindscreen
Sets the rear entities (windshield) to be used to create the bonnet rear reference line.
- hm_wadlinessetwipers
Sets the wiper entities for a WAD lines analysis.
- hm_writemeshcontroltemplate
Writes out the Mesh Control template file.
- hm_writeviewcommands
Sets the state of writing certain view commands to the command file.
- hm_xformnodetolocal
Returns the coordinates of a node relative to a local coordinate system.
- hm_xformvectoratpointtoglobal
Returns the global components of a vector defined at a node and relative to a local coordinate system.
- hm_xformvectoratpointtolocal
Returns the local components of a vector defined at a node and relative to the global coordinate system.
- hm_xpointlocal
Transforms a coordinate into a local system and returns the x value of the transformed point.
- hm_xpointvectorlocal
Transforms a vector into a local system and returns the x value of the transformed vector.
- hm_ypointlocal
Transforms a coordinate into a local system and returns the y value of the transformed point.
- hm_ypointvectorlocal
Transforms a vector into a local system and returns the y value of the transformed vector.
- hm_zpointlocal
Transforms a coordinate into a local system and returns the z value of the transformed point.
- hm_zpointvectorlocal
Transforms a vector into a local system and returns the z value of the transformed vector.
- hwct_getinfofromlibrary
Query information from a currently connected library.
- Deprecated Tcl Query Commands
The list of deprecated Tcl query commands, and the new commands to use.
- Undocumented Tcl Query Commands
The list of undocumented Tcl query commands.
