hm_attributereferencecount
Returns the number of times an entity is referenced as an entity attribute.
hm_attributereferencecount entity_type entity_name_or_id ?search_type?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
To get the number of times material 6 is referenced as an entity attribute:
hm_attributereferencecount material 6 -byid
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
