Get information about all entities of the given type in the current model. A single
call returns a list where every HyperMesh entity of the specified
type (currently only assemblies, components, multibodies, materials, and properties are
supported) is represented with a single list item. Each list item is identical to the return
value of the command, hm_entityinfo all for that entity.
hm_allentitiesinfoentityType
HyperMesh Tcl Query Command
entityType
Type of entity.
For the model on the left (assemblies denoted with folders, components with sheets),
commands hm_allentities assemblies and hm_allentities
components would generate the respective outputs on the right.Figure 1.
