hm_clearmarker
Clears the graphical marker created by hm_plotmarker.
hm_clearmarker ?entity_type? ?<select_type>=<selection>? ?dataname=<data name/attribute>?
HyperMesh Tcl GUI Command
To clear specific markers on specific entities: hm_plotmarker entity_type <select_type>=<selection> dataname=<data name/attribute>
To clear all markers on specific entities: hm_plotmarker entity_type <select_type>=<selection>
To clear all markers on a specific entity type: hm_plotmarker entity_type
To clear all markers: hm_plotmarker
- entity_type
 - The type of entity to clear markers for. Valid values are nodes, elements, points, lines, surfs and solids.
 - <select_type>=<selection>
 - The entity or entities to clear markers for.
 - dataname=<data name/attribute>
 - The data name or attribute to clear markers for.
Examples
To clear the ID data name markers for elements
        1-100:
      *createmark elems 1 1-100
hm_clearmarker elements mark=1 dataname=idTo clear all markers for elements 1-100:
hm_clearmarker elements mark=1To clear all markers for all elements:
      hm_clearmarker elementsTo clear all markers:
    hm_clearmarkerErrors
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
2019.1
