hm_windowtofile
Capture a rectangular area of the screen and save it to a file.
hm_windowtofile x y width height filename
HyperMesh Tcl GUI Command
This command saves to a file the rectangular window area specified by you.
This command is only available and supported on Windows.
- x
 - The upper left window corner x-coordinate. This is relative to the root window.
 - y
 - The upper left window corner y-coordinate. This is relative to the root window.
 - width
 - The width of the window in pixels.
 - height
 - The height of the window in pixels.
 - filename
 - The full path and filename of the image to save.
To get the modeling window coordinates and copy the modeling window to a file:
foreach {x y w h} [hm_getgraphicsarea] {}
hm_windowtofile $x $y $w $h c:/graphicsarea.bmp
Incorrect usage results in a Tcl error. To detect
        errors, you can use the catch
        command:
   # Handle error
}Version History
9.0
