Components Library
Component models share the
following features:
- Components are ready to be connected in the model with no additional modeling requirements.
- Predefined outputs are included covering most of the components desired results.
- Parameters can be included in MotionView or accessed through a property file (TeimOrbit) independent of the MotionView mdl and MotionSolve input deck.
Entity | Function | Features |
Air Spring![]() |
Helical Spring ![]() |
Shock Absorber![]() |
Dissipate the energy stored in springs and damp the chassis motions |
Mount Bushing ![]() |
Elastically mount vehicle components to the vehicle chassis or body |
Frequency Dependent Bushing![]() |
Bump Stop![]() |
Limit suspension bump travel |
Rebound Stop![]() |
Limit suspension rebound travel |
Rider![]() |
Model the mass and inertia of a vehicle driver and passengers |
Tire![]() |
