Open the Design Explorer Browser
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
From the Design Explorer ribbon, Exploration tool group, click the Design Explorer tool.
The Design Explorer Browser opens in the browser area.
Any defined parameters are displayed here. Multiple explorations may be created in any given HyperMesh session. Use the Enabled option to select the active exploration and include or exclude desired design variables, responses, objectives, or constraints before evaluating.
Note: Only one exploration can be enabled at a time.
