Edit a Datum Line with a Microdialog
Use micro dialogs to edit the datum label name and position, or move a datum line in the modeling window.
From the modeling window, double-click a datum line
label.
The datum line label microdialog is displayed.
Figure 1. Datum Label microdialog
- In the Label field, enter a new label name.
- From the Position drop-down menu, select a new location for the datum label relative to the datum line.
Double-click on the datum line to display datum position microdialog.
Figure 2. Datum Position microdialog - Vertical Datum Line
- Enter a value in the X or V field and press Enter to reposition the datum line.
OR
Click the coordinate icon,
, to display an arrow and drag the datum line manually to its new position.
