2024
Annotate plots using notes.
View new features for Altair HyperWorks 2024.
The Developer ribbon contains tools for automation and customization.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Existing curves can be edited individually, and new curves can be added to the current plot using the Define Curves dialog.
Allows you to create macros that produce curves and notes for plots.
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
Add horizontal and vertical datum lines to plots.
Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Move tool.
See Notes for more information.
