Information about the current system or entity can be displayed using the entity note
button. The button is located on the left side of the panel.
From any entity panel, click .
A dialog that contains information about the current system or entity is
displayed. Figure 2. Point Info Dialog
The information dialog displays the following data about the current system or
entity:
Parent
Lists the system parent for the model.
Label
The label field contains the name of an object as it
appears throughout MotionView. A label can contain letters,
numbers, and spaces and can be edited at any time, either on
the editing panel or in the Info dialog.
Variable
A variable name is used to refer to an object when
writing mathematical expressions. The variable name is
unique to an object within a system and can contain letters
and numbers but it cannot contain blank spaces. Variable
names are assigned when objects are created and cannot be
changed.
Allows you to enter additional information on the type of
entity, such as single or pair, or the type of joint, such
as ball or translational joint.
Comment
Comments are used to record information that you want to
associate with objects. A comment can be stored with any
object.
Evaluate IDs and numbers on apply
When activated, the algorithm to compute IDs and numbers
will be invoked after an edit is made to the entity and the
Apply button is clicked.
Number
An integer number can be assigned to every entity or
system and is used whenever numbers are required as
identifiers. If you do not assign numbers to entities, they
are automatically assigned wherever a number field is left
blank when writing out the solver-input deck. Left and right
numbers are listed for an entity pair so a number can be
assigned to each entity in the pair.
ID
An integer ID can be assigned to any entity and is used
to identify an entity when it is written to a solver-input
deck. MotionView automatically
assigns an ID to every entity whose ID field is left blank
when writing out the solver-input deck. Entity pairs have
left and right ID’s so that an ID can be assigned to each
entity in the pair.
Edit the Number or IDs
Select the Number check box.
The numbers are displayed.
Select the ID check box.
The IDs are displayed.
Click inside the Number or ID text box and edit the value.
Click OK to apply the setting and close the
dialog.
Optional: Deactivate the Number or ID check box.
The numbers and IDs are concealed, and the button changes back to its
original state.
