Flexbody solved in MotionSolve
From the Select application menu, select HyperView
Click the Open Model button
on
the Standard toolbar, or from the File menu select .
See Opening Files in HWD for additional information. -
From the Load Model panel, verify that the Load model and Load results check
boxes are activated.
Click the Load model file browser
The Load Model File dialog is displayed. -
Open the .h3d result file.
The same file is automatically loaded into the Load results field.
- Click Apply.
