CAD
If the Graphics panel is not currently displayed, select the desired graphic by
clicking on it in the Model Browser or in the modeling window.
The Graphics panel is automatically displayed.
- From the Properties tab, click the File Name folder icon and select a CAD graphic file.
- Click the Body collector and select a body from the modeling window, or double click the Body collector to open the Model Tree (from which the desired body can be selected).
- Click the MaterialProperty collector and select a material property to associate with the graphic.
Select the desired components from the graphic file.
Tip: If various components are required, select them from the list. If all components are required, click Select All
. You can also reverse the selection status of the components in the list
by clicking Reverse Selection
Define the location properties of the graphic.
- Click the Inertia Properties tab and review the mass and center of mass coordinates for the graphic.
