Animate Flexible Body Mode Shapes
Select the mode shape from the loadcase drop-down in the HyperView Results Browser (as shown below).
Click on the triangle next to the Set Animation Mode button
, and select the Modal animation mode
Click on
to animate the model.
To control the speed of animation, click on the Animation Controls button
- From the panel, use the slider bar located under Max Frame Rate.
To control the rate of deformation in the visualization, use the Angular
increment drop-down menu.
To view animation for a different mode, simply select the mode through the
subcase drop-down menu in the Results browser.
The animation will update automatically.
