Use the List Browser for arbitrary grouping partial FE models and
exporting to solver decks for analysis.
From the menu bar, click Aerospace > Assembly > List Browser.
Use the List Browser to group elements, components, parts, loads,
sets and systems into a single list entity regardless of the parts/subsystem/CAD BOM
organization maintained in the Model/Part/Subsystem browsers. You can select or
drag-drop entities in the List Browser and export the list to a
solver deck. This export gathers all of the related information, such as materials,
properties, laminates and beam section data referred to by elements, components and
parts, to the analysis decks.Figure 1. List Browser Supported Entities
You can set up an analysis run of a small portion of a model. Many lists can be
created in the List Browser, including duplicating the elements,
parts, loads, sets and systems in multiple list groups. This is not possible using
parts/subsystems where the uniqueness of elements/nodes is required.
Access additional List Browser options from its right-click
context menu.
