Contour a single designpointset or designpointmethod. Method inputs and outputs are
available to contour with aggregations.
From the Certification ribbon, click the Contour
tool.
Select a designpointset or a method.
When a run is done on elements without a designpointset, you need to directly
select a method of interest using the designpointmethod advanced selector. Only
a single method can be selected.
If a designpointset is selected, you can
contour any of the assigned methods.
Click on the guide bar to
proceed.
A dialog opens with options for creating contour or marker
plots.
Define contour options.
Pick a result table related to the selected method.
In the case of method selection, this is valid if the same method ran
multiple times (without deleting previous tables) or if it ran both
on a designpointset and directly on elements.
If a designpointset is selected for contour, the Table option lists
result tables for all methods assigned to the designpointset. The
selection defaults to the consolidated table attached to the
designpointset. Such a consolidated table is created whenever
multiple methods are assigned to the designpointset and at least two
of these methods have output flagged as “marginofsafety” (see Methods). This table performs a comparison
between these methods and retains only critical values as well as
method ID.
Select a loadcase or envelope, if applicable.
If results are available for layers, select the layer of interest or
envelope.
If using envelope for either loadcase or layer, select the sorting
key which defines the way data are sorted.
If envelope is selected for layer only, then the min (max | absmin |
absmax) is searched across layers for the selected load case.
If envelope is selected for load case only, then the min (max |
absmin | absmax) is searched across loadcases for the selected
layer.
If envelope is selected for both layer and loadcase, the same sorting
key is used for both.
Select a binding a data type.
Some methods can have results on elements, and some can have output
only at the designpoint level.
If Entity Column is set to elementid, the contour will be
element-per-element.
If Entity Column is set to DDP, then if values are available per
element on the designpoint, the Sorting key will apply. In turn, the
min (max | absmin | absmax) value across elements will be retained
and contoured on all elements of the relative designpoint.
Value Column lists all (float) inputs and outputs of a method valid
for contour. The contour plot is based on this value. In the case of
any sorting, it is used as a sorting metric.Figure 2. Contour per elementFigure 3. Contour aggregated to Structural Beam
Click the Marker tab to define markers options.
Markers can be created with or without a contour.
Selecting multiple options
appends comma-separated values to the entity bind. In the case of a
consolidated table, extra options for Method ID are available, which help to
display the critical method on top of the margin of safety contour.
A
shape can be added, which results in a sphere being placed on each entity
defined in Entity Column. The shape can also be colored based on a separate
legend defined by three ranges.
Restriction: There are sometimes scale issues with spheres on
some models which result in spheres too small to be clearly seen.
The same options available in the Contour tab are also available here.
They control the markers and not the contour. Apply & Reset applies
change to markers only. Hence, it is possible to show a different marker
value than the active contour.Figure 4.
