Intersect Solids
Use the Boolean: Intersect tool to retain only the intersecting portions of two sets of solids.
When you select the Boolean: Intersect tool, a guide bar appears that allows you to select two sets of entities. The first set of entities selected are called targets, and the second set of entities are called tools. In order to produce a meaningful result, the two sets of entities must intersect.
Restriction: This tool supports 2D and 3D element intersections. 1D elements are not supported.
  1. From the 3D ribbon, click the Boolean > Intersect tool.
  2. Select targets.
    1. Verify that the Target selector is active on the guide bar.
    2. Select solid entities to use as targets.
  3. Select tools.
    1. Click the Tool selector on the guide bar.
    2. Select solid entities to use as tools.
  4. On the guide bar, click Intersect.
