Split with Nodes
Use the Split: Nodes tool to split surfaces using ordered (node list/path) and non-ordered node selections or FE edges.
Note: This tool is supported for FE geometry.
From the Topology ribbon, click the tool.
- Optional:
Select surfaces to split.
Note: Target surface selection on the guide bar is optional if only two nodes are selected. If selecting a node list or node path with two or more nodes, you should select the target on the guide bar before selecting nodes.
Activate the Tool selector on the guide bar then choose whether to slit with FE edges or
nodes.
If using nodes, make your selection according to the following table.
Option Description Nodes Left-click on 2 nodes. Node List Left-click on individual nodes to create the desired path. Node Path - Click
on the guide bar to launch the advance selection menu
and select by path. - Left-click to create the path's start and end points. A preview of the path will be displayed.
- Click
- Click Split on the guide bar.
