EXODUS Interface
Overview of the EXODUS interface.
The EXODUS interface enables you to store a large amount of topological and result data in a binary format for finite element analysis.
In HyperMesh, the import and export of EXODUS files is supported in the EXODUS interface. An EXODUS file (*.ex, *.exo, *.ex2) can be read using , and the finished model can be written using .
EXODUS supports the following types of entities, which can be
created from the Solver Browser:
- Blocks (Component)
- Control Cards
- Coordinate Frames (System)
- Functions (Curve)
- Loads
- Materials
- Plots
- Sets
- TiedJoints (Group)
The following loads are migrated to new loads:
- Acceleration
- Boundary
- Flux
- Force
- Moment
- Pressure
- Temperature
- Velocity
- Legacy decks are realized to new loads on import of binary or ASCII file exported from previous releases.
