Interfacing with Animator DB
Overview of how the HyperView applications interface with Animator DB.
HyperView supports Animator DB files from version 2.2
onwards, with the following abilities and limitations:
- Only the first Animation model is read from a multi-model a4db.
- Adaptive models are not supported.Note: For XY plot data support refer to the ../../../interfacing_hypergraph.ditamap section.
- The following element types are supported: Quad, Quad8, Hexa, Hexa20, Bar, Beam, RBE, nel, Mass, Spring, Joint, Spotweld
- Components are created based on the property information, if there is no property associated with an element, such elements are grouped under the component id = 9999.
- Reading of following results is supported:
- Displacement
- Failed elements (mapped to eroded elements in HyperView )
- Functions (mapped to scalar datatypes in HyperView )
- Function_node_element (mapped to scalar corner data in HyperView )
- Vector4 (mapped to vector datatypes in HyperView )
- Tensors (mapped to tensor datatypes in HyperView )
