Enable Mesh Controls
When a meshing job is submitted, enabled mesh controls are considered and used to automate the meshing process.
In the Mesh Controls Browser, enable and disable mesh
controls.
Option | Description |
Model mesh controls | Multiple instances of model mesh controls can be defined, but only
one can be enabled.
Local mesh controls | An unlimited number of local mesh controls can be defined and
enabled.
Refinement Zone controls | An unlimited number of refinement zone mesh controls can be defined
and enabled. Each refinement zone can be independently enabled or
disabled for surface meshing (surface deviation only), adaptive wrap
meshing, and volume meshing as required.![]()
