Fuse Closed Shells
Use the Fuse: Closed Shells tool to create watertight volumes for CFD and thermal applications with closed shells.
From the 2D ribbon, click the tool.
- Optional:
On the guide bar, click
to define fuse options.
Activate the Source selector on the guide bar, choose Components or
Elements, then select source entities.
Source entities will move to the target.
Activate the Target selector on the guide bar, choose Components or
Elements, then select target entities.
Target entities will not move.
- Click Fuse all on the guide bar.
