Classify
Classify parts by predicting their label and creating part sets.
Perform this task on parts that do not have manually assigned labels.
From the Assembly ribbon, click the
tool.
- From the guide bar, select the Classifier drop-down menu to select an existing classifier.
Files drop-down menu to select a trained machine
learning model file from the selected classifier’s folder.
The Parts selector activates.
- With the Parts selector active, select the parts to classify under the labels of the selected classifier/trained model.
From the guide bar, click
to set a value for the Certainty Ratio (see Certainty Ratio, Unclear Predictions, and Unrecognized Parts).
Click Classify to classify the selected parts.
The parts are color-coded based on the predicted labels. The legend that is displayed after classification is complete is temporary and only remains while you are using the Classify tool.
- Part sets are created for review and traceability after exiting the Classify tool.
For example, if a machine learning model trained to distinguish springs from dampers is used to classify wheel rims and suspension control arms, the spring and damper labels are also going to be assigned to all wheel rims and control arms selected for classification.
When a part is processed by a trained machine learning model, the likelihood of the part matching each label is calculated. Sometimes, predictions are returned that the machine learning model knows are uncertain.
- If the certainty ratio calculated for a part is greater than the threshold
value, then the machine learning model prediction is considered uncertain,
and the part is assigned to a part set
named:
<label_name>Unclear(_<certainty_ratio>)_<iteration>
- If the certainty ratio calculated for a part is lower than the defined
threshold, then the prediction is considered certain enough and the part is
named:
<label_name>(_<certainty_ratio>)_<iteration>
- If the part does not appear to be shaped like any parts that have been
labeled, then the machine learning model marks the part as unrecognized and
assigns it to a part set
named:
Unrecognized(_<certainty_ratio>)_<iteration>
Add Trained Model File
Add a third-party trained machine learning model file.
The resultant binary (.aic) files from model training can be shared and used on different machines.
tool.
to select a file for Add Existing .aic File.
A new classifier folder is created in the project directory and a duplicate of the trained model file is saved in it, which you can use later for classification.Note: You can use these models for classification, but you cannot label additional parts in this classifier or retrain it.
