Execution mode. Interactive mode will be slower than background
mode.
Default/Allowed: interactive or background
input
Initial director for CAD Input.
Default/Allowed: C:/temp
output
Initial director for results output.
Hole Detection
min-diameter
Minimum diameter for surface hole recognition. Holes below this diameter
will be ignored.
Default/Allowed: 1.0 to 10.0
max-diameter
Maximum diameter for surface hole recognition. Holes above this diameter
will be ignored.
min-nodes
Minimum number of nodes to recognize FE hole. Holes with nodes less than
this number will be ignored.
Default/Allowed: 4 to 10
max-nodes
Maximum number of nodes to recognize FE hole. Holes with nodes greater
than this number will be ignored.
Default/Allowed: 30 to 50
adjacent-tolerance
Distance to judge duplicate holes for the same plate. If the Holes to
Holes distance is less than this value it is considered as a duplicate
hole.
Default/Allowed: 3.0 to 5.0
Free Hole
do-check
Turn OFF or ON the check.
Default/Allowed: ON or OFF
elem-adj-bbox-tolerance
Search tolerance for searching nearest bolts/nuts from the hole
center.Figure 1.
Default/Allowed: 10.0
If there is no bolt, nut or screw nearby, the holes are considered as free holes.Figure 2.
freeboltnut
do-check
bolt-box-tolerance
Search tolerance for searching nearest plates from the bolt outer
surfaces.Figure 3.
Default/Allowed: 1.0 to 5.0
nut-box-tolerance
Search tolerance for searching nearest plates from the nut outer
surface.Figure 4.
Default/Allowed: 5.0 to 10.0
allowed-plate-comps
These named parts will not be considered as plates.
Default/Allowed: string names of special parts
Bolt or Nut CAD data that are not passing through the plates or floating in the space
without the plates are found.Figure 5.
bolthole-mismatch
do-check
input-type
Continuous CAD lines or CAD solids.
Default/Allowed: lines or solids
centernode-search-tolerance
Search tolerance for searching holes from bolt CAD surface.Figure 6.
Default/Allowed: 1.0 to 2.0
Tolerance for searching nearest plates from the bolt outer surface.Figure 7.
min-dist
Allowable mismatch distance between bolt axis and hole axis.Figure 8.
Default/Allowed: 0.1 to 1.0
max-dist
Maximum search distance between bolt axis and the hole axis.
Mismatch issues are found if the mismatch is between min-dist to max-dist value.Figure 9.
nuthole-mismatch
do-check
input-type
Search tolerance for searching holes from bolt/nut CAD surface.Figure 10.
Tolerance for searching nearest plates from the nut outer surface.Figure 11.
min-dist
Allowable mismatch distance between nut axis and hole axis. If the
mismatch is less than this value issues will not be reported.Figure 12.
max-dist
Maximum search distance between nut axis and the hole axis. If the
mismatch is greater than this value issues will not be reported.
Issues are found if the mismatch distance is between min-dist to max-dist range.Figure 13.
boltnut-mismatch
do-check
Tolerance for searching nearest plates from the nut outer surface.Figure 14.
threshold-angle
Allowable angle between center axis of bolt and the nut. More than this
angle, the check will be ignored for that pair of connection parts.Figure 15.
Default/Allowed: 10.0 to 30 deg
min-dist
mismatch is less than this value issues will not be reported.Figure 16.
max-dist
mismatch is greater than this value, issues will not be reported.
Bolt-nut mismatch issues will be reported if the Bolt and Nut sizes are not within
min-dist and max-dist range.Figure 17.
boltnutsize-mismatch
do-check
Tolerance for searching nearest bolt, plates from the nut outer
surface.Figure 18.
min-dist
mismatch is less than this value issues will not be reported.Figure 19.
min-nut-tol-bolt-ratio
Allowable minimum ratio between bolt and nut size. If the ratio is less
than this value the issue is reported.Figure 20.
Default/Allowed: 0.8 to 0.9
max-nut-tol-bolt-ratio
Allowable maximum ratio between bolt and the nut size. If the ratio is
greater than this value the issue is reported.Figure 21.
Default/Allowed: 1.1 to 1.3
Issues will be reported if the Bolt size and Nut size are not within the range of
min-nut-tol-bolt-ratio and the max-nut-tol-bolt-ratio.Figure 22.
holes-mismatch
do-check
min-dist
mismatch is less than this value the issues will not be reported.Figure 23.
max-dist
Maximum search distance between hole center node axis.
Tolerance for searching nearest plates from the hole center.Figure 24.
Tolerance for searching nearest plates from the hole center.Figure 25.
Issues will be reported if the center axis distance between two holes are not with
the min-dist and max-dist.Figure 26.
holespair-mismatch
do-check
Tolerance for searching nearest plates from the hole center.Figure 27.
Tolerance for searching nearest plates from the hole center.Figure 28.
Holes not found in the nearest plates are reported as an issue nearest plates. Plate
holes are searched with centernode-search-tolerance tolerance.Figure 29.
Clip-mismatch
do-check
input-type
Search tolerance from center clip to holes center.Figure 30.
min-dist
Allowable mismatch distance between clip axis and hole axis.Figure 31.
Default/Allowed: 0.5 to 1.0
max-dist
Maximum distance between clip axis and the hole axis. Greater than this
value the clip parts are ignored in the check.
Default/Allowed: 5.0 to 15.0
Issues will be reported if the center axis of clip data and the center axis of the
hole node is greater than the min-dist and less than max-dist.Figure 32.
Arc/Seam/Adhesive/Seal/Hemming -mismatch
do-check
input-type
elem-adj-bbox-tolerance (tol)
Search tolerance for finding the nearest weldable plates. If less than
two parts are found the issue is reported.Figure 33.
min-dist
Minimum distance between arc weld to the nearest parts. If less than two
Default/Allowed: 0.1 to 5.0
max-dist
Maximum distance between weld lines to the nearest parts.
Finds shape mismatch between the weld lines against the plates with the given min and
max distance.
The mismatches are measured from the end points of the line.Figure 34.
