Predict Results
Use the predict tool to generate a model prediction.
- Drag-and-drop an FE model file into the modeling window.
In the Load File dialog, define the options for the model
and click OK.
In the Import Options dialog, click
Import.
The model opens in the modeling window.
From the PhysicsAI ribbon, select the
Predict tool.
The prediction will load in the modeling window.
